Results 1 to 8 of 8
    Sep 04 2012
    Menomonie, WI
    Unhappy location of intake camshaft sensor
    i have a 2008 audi a4 2.0t and my check engine light is on. It says that my intake camshaft is messed up, so i was wondering where it is located at so i can replace it. thanks for any advice.
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    dont know which side but there is one (if you are standing in front of the car, I think) right front corner below the valve cover and the other back left corner off the valve cover. Not attached to the valve cover just in that general vicinity.
    Sep 04 2012
    Menomonie, WI
    do you have any pictures of it? if u do greatly appreciated.
    Jun 19 2009
    17 ram 1500
    Hartford CT
    i wish it's sort of hard to explain without pictures. But the one on the right front corner sort of enters the engine in almost the same position as a injector. look for the harness going into it, might have to lossen the top of the timing belt cover if i remember correctly and i think 1 T-20 screw holding it in.
    The other near the rear left corner after the valve cover is sitting up right and you can see the harness running into it almost like the hpfp harness. It has 2 small screws holding in and have to remove a bracket (triple square type screw) to get one of the screws all the way out to remove it.
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Quote Originally Posted by Chou View Post
    What code do you have? there is a position sensor and an adjustment valve. Your dtc would be helpful in us helping you with the correct part
    New Build, 2010 Tiguan. Details to com
    Sep 04 2012
    Menomonie, WI
    i have a p000a code.
    Jun 27 2011
    That code refers to the cam adjuster (N205).
    Oh hai!
    I would run through a few diagnostic procedures listed HERE before I dropped $150 on that N205 though.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 06 2011
    Harrisburg, Pa
    Oh hai!
    Can't say it any better myself
