Results 1 to 8 of 8
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 10 2010
    STL, MO
    Pushed in Parking Sensor
    So, I walk outside to my car after my morning trip to Starbucks, and find this when I walked around my car. I'm not sure how this happened, but I'm assuming someone got a little touchy feely with my car, as I can't imagine it would just fall into the hole on it's own. Either way, does anyone know how to fix this without taking off the bumper? BTW, I spent the weekend driving on a gravel road, hence the dust. The car isn't always that dirty
    Veteran Member Four Rings Fade2Black's Avatar
    Nov 27 2008
    Black B6 S4
    Springfield NJ
    I could imagine a little kid walking by and pushing that in.
    The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.
    – Thomas Jefferson
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    It is not fun to do but you can push that sensor back into place without taking off the bumper.
    There should be a cover that you have to take off between the bumper and spare tire wheel then reach up there and push the sensor back into place. It has been a while since I had to do this but I remember cutting my arm up pretty good.
    Jul 10 2010
    STL, MO
    Quote Originally Posted by JimmyBones View Post
    So from underneath the car?
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by FulhamFTW View Post
    Yes
    Jul 10 2010
    STL, MO
    Yes
    Thanks, I'll give it a go and see it that works.
    Jul 10 2010
    STL, MO
    Just fixed it. It was actually quite easy and took me a whole 5 seconds to do once I was under the car. The wires for the sensors are clearly visible behind the bumper and all I did was push it back out. Problem solved!
    Mar 22 2010
    nyc
    yea that would sucked pulling off the bumper.
