I haven't been able to locate much info for this system. I have a pump which won't turn on shortly after having the turbos replaced. Pump is fine, I even replaced the bearings. Hot jump it runs great. 40A fues is ok. Relay never picks to cause it the run. Fuse for the relay is good as I have 12v @ the relay coil. Coil is good and will pick if Grd is applied to coil. So is my ECU now bad?
What is the condition to cause this to run? I'm told it will run if theCATs are cold. OK, so how does it know they are cold? Does it look at ambient temp, EGT sensors? If I can find out what causes this system to decide it needs to run then perhaps I can decipher how to fix the actual problem. Thanks, George
