Results 1 to 8 of 8
    Dec 17 2011
    westminster ca
    Need a suggestion or review on twin disk clutches
    I am going to replace the twin disk clutch on my s4 because its starting to slip. The previous own had Tilton twin disk clutch and flywheel kit. Should I go with the same or another brand?? The car makes 500+hp and 500+ft/lb torque. Any input/suggestions would be appreciated.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Quote Originally Posted by apacman316 View Post
    500 hp.. or 500awhp? what exactly do you want in a clutch for feel/engagement/life...
    need more info
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Dec 17 2011
    westminster ca
    awhp...
    if i had to order the importance is
    1. life
    2. engagement
    3. feel
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    wait are you looking to rebuild the tilton or getting a completely different clutch?
    Sep 17 2005
    Fremont, California
    awhp...
    1. life
    2. engagement
    3. feel
    Your 3 primary requirements are 3 things that are typically not found in twin disc clutches.
    Twin Discs allow for way more clamping force, and disperse that force over two discs. They are a performance part, and the primary function is to hold the power, and not drive great around town.
    Tilton's are one of the best twin disc clutches made, and their new Cerametallic discs last longer then before, but it is still a high clamp and high friction clutch kit. Engagement will be rough and quick, but the feel will be solid and consistent. You can rebuild your Tilton clutch for very cheap. You can have the friction surface replaced and discs replaced for a few hundred dollars. However, the average life of the clutch will be less then that of a typical single disc. In the end, it is still an unsprung twin disc performance clutch designed to hold +700ft/lbs
    There are twin disc clutches that do drive better, but you will make sacrifices in performance. For example, another great twin disc clutch is the Clutchmasters TD850 (FX850 to some). The reason it can drive better, is because there are a variety of pressure plate and disc options. You can opt for a lighter pressure plate, with a combination of sprung and unsprung discs. However, the clutch is 8.5" diameter and quite heavy compared to a Tilton 7.25", and also about twice as expensive. They can last a long time depending on the discs.
    Your cheapest option is to rebuild your Tilton.
    If you want a single disc clutch that drives well with little effort but holds 500hp, I highly recommend the Southbend Stage 4 Extreme. This is what I run on my own 600whp S4, it is what my coworker runs on his 600whp S4, and also a clutch used by a variety of friends and customers with big power cars. You won't be able to beat on it like a twin disc, but if you are mindful, it can last +30,000 miles and hold your power. I can offer you a great deal on the clutch and flywheel combo, or I can help you rebuild your Tilton for cheap.
    Dec 17 2011
    westminster ca
    thanks max!!! i will do some more research and will decide what to do...awesome post!
    Veteran Member Four Rings AudiForeman's Avatar
    Apr 24 2011
    B5A4T.06R1.B5S4
    co719/303
    I have 600 miles on my tilton twin and love it, sometimes sucks around town but once you figure out the friction spot its really not too bad. When mine goes out I will rebuild it.
    May 16 2008
    South Texas
    I've got a dozen or so Southbend Stage IV extreem clutches out there and it's been a great clutch a few people have repleced twin disc clutches after their twins' wore out and have not looked back.
