Originally Posted by
alterdcreations
hey guys. i have been thinking. i want more power out of my 4.2 and i think a engine swap would be second best to buying a rs6.
i have a 01e swapped 4.2 and after looking around for info i think it can be done faily affordably. i would think that the stand alone ecu would be the most trouble.
so far from what i understand the rs6 4.2 zf transmission and the w12 transmission are the same. if so then a rs6 6speed adapter plate and flywheel should bolt up........but the w12 from the a8 is different from the w12 in the pheaton. does any one have any more info?
Not entirely true. The first gen W12 shares a similar transmission (5HP24) as the RS6 however I'm not sure how similar it is in terms of the bellhousing. Later W12's use the same transmission family as the V10 (6HP26 IIRC).
But we didn't get that engine in the D2. I suspect that the bell housing is the same, but you'd be on your own investigating this. Also the early W12 engines are crap, something like 80% of them broke crankshafts. Also the flex plate and starter are different on the W12 so that also may be an issue.
The W12 is also a very wide and heavy engine, it is quite a bit wider than the V8 by about 6 inches if my memory isn't failing me, so fitment into the A6 may be a problem as well.
I'm not saying it can't be done it would probably be way cool but since you'd be the first plan on spending some good money for the research.
