I noticed a bit of an oil leak coming from the back of the engine block. It's coming from what appears to be a plug/valve of some sort. In the image below, the yellow stick is touching the problem area. I have no idea what this thing is called or what it does, so any insight as to it's name or function would be helpful.
It's located on/near the back right corner when facing the engine block, and is almost directly beneath the radiator overflow tank.
There is another on the opposite side of the engine, and it also is leaking oil.
EDIT: Now with less blurry photo
Additional information or photos can be provided upon request.
