Results 1 to 10 of 10
    Jul 27 2010
    Queensland, Australia
    Dynomax VT long term review
    So I purchased a dynomax VT muffler through Jeff Lee sometime last year along with the 520 psiconcepts turbo kit.
    The part number for the one I have is 17157 ie below 4L application as per Jeff Lee's recommendation.
    When I first got it, I just installed the muffler on its own. However, it sounded very rice...very honduh kind of way. I installed a resonator in the middle few days after that(couldnt bear the noise it emits lol)..helped a bit...
    On the positive side, at cruising speed, its very very quiet.
    So push forward today...the rattle from the muffler's butterfly is driving me nuts. Videos will speak for itself.
    and here is the killer video
    Its by far the shittiest aftermarket muffler ever made. Period.
    Ps: its not Jeff's fault in any way. Dynomax really need to look into this.
    What's a good quiet setup you guys run? 2 mufflers(ie mid and rear)?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Wow, that just made up my mind not to get it. I thought they added a little foam thing to the flapper? But I don't think it would last long term.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jul 27 2010
    Whatever they had sticking to the flapper didn't last for a year.
    Best bet is to run X-force's Varex muffler.
    Theyre very pricey...If I could get them for cheap, it'd be great substitute for the dynomax shitbox.
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
    Veteran Member Three Rings Urtorsen's Avatar
    Feb 09 2009
    chicago
    I was checking on your build over on the OZ site, no updates?? Have you ran the billet wheel yet??how does the psi kit feel?? Got any more videos of a few WOT runs??
    Jul 27 2010
    Repost
    99.5 A4 1.8TQ MT
    Instagram : e85.A4
    Jul 27 2010
    Quote Originally Posted by Urtorsen View Post
    Not much updates bud.
    I need to rebuild the engine as I'm not happy with the compression numbers.
    I bought a custom wilwood 332mm 6pot BBK from a member here. Should fit it this weekend.
    Heck I might start a build thread here. Copy and paste the stuff from the oz forum. lol
    99.5 A4 1.8TQ MT
    Instagram : e85.A4
    Jul 27 2010
    Did another video today.
    I forced the valve to open by sticking a piece of rod. To be honest, the car sounds a LOT better.
    I wonder if its a big job to undo the stupid rattling valves in the muffler.
    Jul 27 2010
    So...the rattle gets worst by the day and I had to something about it. I feel that they should put up a slogan for the muffler "gone drone, hello rattle".
    Went to a friend's house and used an arc welder and tack welded the butterfly to stay open. I know it defeats the purpose of the anti drone, but the tack welding is free, saves me from buying another muffler.
    VERY easy to fix the problem. Find a long rod or small'ish pipe to get the butterfly to stay open, with an assistant shining a light through the muffler, run the arc welding rod in and tack it. Win.
    Here's a video of my car now :-
    FYI Its a 2.5inch downpipe - 3inch pipe - resonator(cant remember size) - dynomax muffler
    Sep 13 2012
    VT/QC
    And how's the drone when driving now?
    Jul 27 2010
    Well, it's not that bad. Just have to feather the throttle for a "sweet spot" quietness lol
    99.5 A4 1.8TQ MT
    Instagram : e85.A4
