Ok. First off, I've been having intermittent issues with the ABS / ESP light turning on followed by speedo that stops working. So I had it scanned and found out that the left front wheel speed sensor was the culprit. After replacing the sensor with an aftermarket part, while on idle, the ESP light would stay on, the speedo needle moving up and down, then followed by the ABS light and eventually speedo needle stops moving and working. How can I get this cleared and fixed? Any ideas? TIA.
