Results 1 to 14 of 14
    Veteran Member Three Rings dcsantos's Avatar
    Dec 01 2010
    Orland Park, Il
    Ecu tune for 98 1.8t aeb
    I have a 98 a4 1.8t and looking to get my ecu tuned by most likely Unitronic, the question I have is how do I know if my car will allow for direct tuning through the obII port or if I need to send my ecu to Unitronic. I called the shop where I'm going to get this done and he said because how old my car is I might need to send in my ecu.
    Dec 01 2010
    Orland Park, Il
    Anyone possibly
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    call unitronic
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Mar 24 2011
    MTL
    Your AEB is a 557P, and that ecu is not flashable, meaning they need to physically solder the chip to your ecu.
    Dec 01 2010
    Orland Park, Il
    Does this go for all 98 a4's or is it possibility I can still be flashed my 98 is a 98.5
    Oct 21 2005
    y
    Quote Originally Posted by A.K. View Post
    Quote Originally Posted by timothyjmares View Post
    The 557P is flashable. I'm just not sure if tuners give out flashers for it, but it is definitely flashable via OBD. No need to solder.
    Jul 27 2010
    Queensland, Australia
    Maestro has a stage 1 and other files for your car.
    99.5 A4 1.8TQ MT
    1.9L built/blueprinted motor, JE assymmetrical pistons, IE Tuscan Rods-JNL racing custom ported head, IE CVA2 camshafts-BW EFR7064 .92 IWG-Full-race T4 manifold-1150cc injectors +++++++++
    Instagram : e85.A4
    Dec 01 2010
    Orland Park, Il
    When you guys say 557p is that a number that should be listed on my ecu?
    Jul 27 2010
    Quote Originally Posted by dcsantos View Post
    Yes. On top of my head, it should read out 8D0 907 557P.
    Mar 09 2008
    Torrington, CT
    I believe Unitronic flashes their stage 1 files for that ECU, but they require the ECU to be sent to Canada for the BT files.
    You used to be able to check on their website.
    Dec 01 2010
    Orland Park, Il
    So your saying if I get a bt tune I'll need to send it to Unitronic? Because I want to tune my ko3 with Unitronic so it should be flashable through the obII?
    Dec 01 2010
    Orland Park, Il
    I'm looking to go stage one+ will that matter?
    Mar 09 2008
    Torrington, CT
    I believe that will be a flashable upgrade, but just check unitronics site.
    Dec 01 2010
    Orland Park, Il
    Just called the place I will be getting my ecu tuned with called "mobile one in glenview il" and they said my ecu was flashable which is 8D0 907 557P. Can't wait to get my stage one + from Unitronic !
