Results 1 to 26 of 26
    Senior Member Three Rings A4 Joe's Avatar
    Jan 31 2007
    tire pressure for daily driving?
    I checked my tire pressure a couple of days ago and all four were just below 35 PSI. I have the OEM 19's with the Conticontact 3 tires. The tag on th B pillars indicates 41 PSI cold. The manual shows a range and also shows a couple pounds less in the rears than in the fronts. I pushed all four to 41 PSI and seems to handle well with a bit more firmness in the ride.
    I do not plan on tracking car. Mostly city traffic and freeway driving in Los Angeles.
    What are folks here running?
    Thanks for replys.
    2019 S5 Sportback. Quantum Gray. Black Optics
    Feb 13 2004
    Silicon Valley, CA
    I was running 38 all around on my 19 with the Pirellie PZero Rossa tires that came on the car and after 15k miles like that, the centers are totally worn on the tires from over inflation. Make sure to keep an eye out for that.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by A4 Joe View Post
    Thanks for replys.
    I am running what's printed on the door jamb, and that's what you should too. Audi doesn't arbitrarily spec an inflation. I see no reason to change it unless you are heavily loading the car.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Senior Member Three Rings motorboatingsob's Avatar
    May 01 2012
    West Chester, PA
    Quote Originally Posted by dparm View Post
    Aren't those pressures based on a fully loaded car?
    2011 S4 | Pearl Black | Silk Nappa | 6MT | Sport Diff | Nav | ADS | B&O | SC Badges | 20% Tint | Tinted Tails | HID Fogs | int/ext LEDs | RS4 Pedals | STaSIS V2 Tune | Eurocode Shortshifter | APR Carbonio Stage 1 & 2 Intake | Alu Kreuz | E-Code Headlights | AWE Boost Gauge | AWE Non-Res Exhaust |
    Active Member Three Rings
    Jul 30 2012
    New Jersey
    they are max pressure. see the manual for recommended pressure. i do 35 psi on my 19's
    Sent from my SCH-I535 using Tapatalk 2
    Veteran Member Four Rings IanVr6's Avatar
    Jan 07 2010
    New Orleans
    I do 40 cold on those same tires.
    2015 BMW M4
    2014 Jeep Grand Cherokee SRT
    2012 Audi S4 - totaled
    2008 VW R32 - sold
    2000 VW Jetta VR6 - sold
    Veteran Member Four Rings Akrion's Avatar
    Dec 24 2010
    Quote Originally Posted by s4ibis View Post
    I do 35 psi on my 19's
    Same here...
    May 01 2012
    West Chester, PA
    I have always just dropped factory by a few pounds. I run 38 and seem to have good even wear
    Mar 26 2010
    US
    The door pillar is pressure for full loading (for liability reasons). At high speed, underinflated tires can can excessive heat.
    When I recieved my car from the dealer, it had 41lbs all around and was very bouncy on the 101 freeway, near Rector Audi. Putting it at the recomened standard pressue, the car was less bouncy.
    The standard loading recommened cold tire pressue is in the S4 manual, which is what I run.
    19 inch stock tires 36lbs F, 33lbs R
    18 inch stock tires 39lbs F, 35lbs R
    BMW M3 Competition X-drive
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by motorboatingsob View Post
    Sorry, meant to say based on the owner's manual.
    Jan 31 2007
    I always was told follow the sticker on the car. My owners manual even references the sticker as the final word. The 41 does seem a bit high. I wonder why the rear pressure is lower. Must be to minimize understeer associated with all wheel drive. 33 on the rear seems low. Think I will go to 38 front and 35 rear for a while and see how it feels.
    Apr 24 2009
    Frisco, TX
    I don't think 41 is high. These are heavy cars.
    Again, go with what's on the sticker/manual. Why playing guessing games?
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    I went with pressures in the manual
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Apr 04 2012
    MSP
    I run 35
    Jan 31 2007
    I think the question here is which of those to follow. Sticker says 41. Manual full loaded say 41....Manual at standard load says 36/33
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    I go with the numbers on the sticker.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Mar 26 2010
    US
    The answer is follow the manual, for light loading (three people or less), use the lower pressures.
    One can use the max loading air pressures, with a light load, if it makes you happy, but the ride is not so good with higher pressure.
    The higher pressue is usefull when loaded heavily or driving at high speed (90mph or more) for extended periods of time (multiple hours).
    Senior Member Two Rings ccssid's Avatar
    Jul 03 2011
    michigan
    installed contis dw extreme and the dealer looked at dor jamb...went 41 on all 4.....drove like sh**t. dropped to the manual specs +1 pound. drove like a dream
    Veteran Member Four Rings CreoSTi's Avatar
    Feb 22 2004
    West L.A.
    I run 38 psi all around. Best compromise for comfort/handling to me, and no uneven wear...
    -Mike-
    2022 Tesla Model 3 Performance & 2023 SQ5
    Past: 2001 S4, 2011 S4, 2014 S6, 2018 S4, & 2021 TT
    CrossCountry Mortgage
    Instagram: creoucla
    Veteran Member Three Rings vwong's Avatar
    Apr 03 2006
    '10 S4, '09 335i, '98 Prelude
    I run 36psi all around in my 19" Yokohama AD08 tires.
    2010 Audi S4 6MT
    2009 BMW 335i Coupe 6MT
    YouTube Channel
    Senior Member Three Rings Riu's Avatar
    Apr 03 2011
    Boca Raton Florida
    Funny story. I had a low tire one day at work. So I stopped at the gas station and pumped it up but did not have a gauge in my car. (I have one now) The one at the gas station was broken. So i drove home and stopped at a gas station close to home.
    I get on the highway on my way to the second station and i feel unstable and the car feels like its ready to just lose it so im going like 40 miles a hour max.
    When I Check the psi it was 59.
    Lesson: Dont do that again.
    I just held it on there for like 20 seconds, wont do that again. lol
    Oddly enough, tire still looked low.
    Veteran Member Four Rings t0mt0m's Avatar
    Apr 26 2005
    Nothern Va
    38 on my conti dws bei cause feel like there a softer tires
    the crap stock pzeros i run at 36/37 because there crap and want them to wear out faster
    B6 A4 1.8t 5MT Quattro - Sold
    B8 S4 '10 6MT Prem+ - Sold
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    I used to be @41 based on the door sticker. I now run 38 all around per the suggestion of a tech at my Audi dealer. It feels great and after 12K miles of that I have very nice even treadwear.
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Veteran Member Three Rings tins5's Avatar
    Sep 21 2011
    Delaware
    I lowered mine slightly today to what the manual says (36/33). I'm not sure if it's in my head, but I noticed that the steering and handling felt much tighter and better, especially in auto mode.
    B8.5 S4 6MT
    Previous Rides: B8 S4 | B8 S5 | MK5 GTI
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Quote Originally Posted by tins5 View Post
    That's only what it says in the manual for the all season tires on the B8.5.
    Senior Member Three Rings Norm_S4's Avatar
    Jul 11 2011
    Repentigny/Quebec/Canada
    its definitely not just a mind game. Front pressure will have a huge difference on steering feel and there's many other factors to consider. The debate can rage on of which to use (door or manual) but I think its biased on what the load is. If you plan to drive a very long time and have 4 adults and a packed trunk, you'd be better off to run higher PSI and if DD you're pretty much alone, anything between and around 36/38 front and 33/35 rear is what I found to be best.
    Funny enough right now I run 35 all around but I'll adjust i the next few days to 36 front and 34 back. I generally drive with a light load around anyways and your driving habits should also warrant how you like things. Higher pressure will make for easier steering even to the point of feeling loose in any settings and lower pressure will go the other way.
    It boils down to what you like to feel on the steering within the recommendations with the user manual/door settings.
    New RS3 2018 Nardo Grey black optics no mods in sight. Sold:2011 S4 6MT/Sport Diff, Sprint Blue, Eurocode full ÜSS system + AluKruez, Roc-Euro Intake, SS Lines + EBC USR rotors/Red Stuff pads on 4 corners
