Results 1 to 19 of 19
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    Thule Aeroblade Roof Rack
    Just purchased and installed a Thule roof rack. The parts are: 480R Rapid Traverse foot pack, ARB53 Aeroblade cross bars, fit kit 1462, and 544 4 pack of lock cylinders. Figured I would post a pic as I could not find any installed on a B8 sedan.
    Install was super easy and these things are sturdy and very quiet. Plan on getting a couple of Rockymount Euro pitchfork bike racks and mounting my yakima ski rack up for the winter. Looked at the Whispbars but chose the Thule rack due to build quality and the fact that the fit kit on the Thule makes the bars more on a level plane with each other.
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Nice. I have the same setup. Too bad the 50 inch bars are only available in europe as they provide the perfect overhang. I tried 47 inch and they were too short in the front and the 53 is a tad too long. Rocky mount euro pitch fork provides the cleanest mount as hardware is well hidden without unsightly clamps. I use clear paint protection film on the car contact points. Won't scratch the paint that way.
    Feb 15 2012
    Montreal/Quebec/Canada
    Quote Originally Posted by audibmi View Post
    Just cut 1.5" from both side... 50" bars :) It's just aluminium. Easy to do.
    2011 S4 Premium \\ Phantom Black \\ Lunar Silver leather \\ Carbon Trim \\ Sports Diff \\ Alufelgen SF71 19x9.5
    Feb 07 2012
    Quote Originally Posted by typer100 View Post
    Yup. I may do this down the road sometime. From Thule:
    Q: I want to use a shorter bar than what Thule lists for my vehicle in the fit guide, can I do that or can I cut down the AeroBlade bar to a custom length?
    A: Thule always recommends the shortest load bar that will fit the vehicle. The Thule Square bars can easily be cut down and the end cap will cover a imperfect cut. To cut down the AeroBlade, it is necessary to cut all four ends in order to keep the bars centered and an imperfect cut will show. Filing the ends can bring an imperfect cut back into square. Additionally, the end cap has a clip that engages into a notch at the end of the under bar slot, if you cut the bar you will cut away that notch, however, the end cap will still press and hold into place without the notch. So, the answer is yes, the AeroBlades can be cut down but it requires more precision and effort. A rotery miter saw with a non-ferrous metal cutting blade would produce the best results.
    Established Member Two Rings fidelcashflo's Avatar
    Aug 18 2013
    SD
    Dang so the 47 inch aeroblades definitely dont fit the B8?
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Quote Originally Posted by audi0321 View Post
    when i initially measured fitment with 47" aero bars, they were from an A3. keep in mind at the time, i did not have the B8 fit kit yet, and because i couldn't tighten the clamps down, the bars appeared to be too short.
    now that i have the actual fit kit for the B8, and everything set up and clamps tightened, i can confirm that the 47" bars work. my measurements are as follows for your reference, but I used a yard stick rather than my digital calipers, so I may be off slightly:
    rear bar overhang on 53" bars is 4" on each side including the notch for endcaps which is 1/2" from each end.
    front bar overhang on 53" bars is 3.5" on each side including the notch which is 1/2" from each end.
    so, according to my calculations:
    rear bars: 53"-4"-4"= 45", so with 47" bars, you will have 1" overhang on each side. You will also be able to retain the notch for the endcaps
    front bars: 53"-3.5"-3.5 = 46", so with 47" bars, you will have 1/2" overhang on each side. You *may* be able to retain the notch for the endcaps, as they are approximately 1/2" from the end.
    front overhang on 53" bars is 3.5" including notch
    rear overhang on 53" bars is 4" including notch
    notch for endcap measured from the end is 1/2"
    Active Member Two Rings El. Cid's Avatar
    Oct 16 2011
    Tampa, FL
    looks very nice. I went with the Yakima Wispbar instead of the Aeroblade for the simple reason it can support a bit more weight but then got the Thule Sidearms that work perfectly for bikes. Both are great options.
    Current- 2016 Audi Glacier White RS7
    Mods: [I] Ceramic Coating [I]APR Stage II [I] Akrapovic Exhaust with DP [I] Eurocode F/R Sway Bars w/ end links [I] 21" Vossen HF-1 [I] Full Nose Auto-film
    Past-2014 Audi Phantom Black B8.5 S5
    Feb 07 2012
    Quote Originally Posted by El. Cid View Post
    Aren't they both rated around 165 lbs. unless you go with the whispbar HD?
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Aug 18 2013
    SD
    Thanks for the help man I appreciate it.
    I went ahead and ordered a set of 53s and 47. Ill let you know if the 47s fit when i get them.
    Aug 18 2013
    SD
    The 47s fit! Got them on tonight with no problem at all. Idk why Thule would recommend the 53s for the B8s because the 47s fit perfectly.
    Took some shitty iphone pics:
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    looks good. Glad it worked out!
    Junior Member Two Rings
    Mar 18 2012
    San Diego
    Just another vote for the 47in aerobars here. They fit perfect on my avant.
    | Past Highlights: B8 A4 Avant, Mk7 GTI, W211 E55, E46 M3, W201 2.3-16
    Nov 03 2013
    Manchester, NH
    I have a 2012 avant and I wanted to purchase Thule's new Aeroblade EDGE, that sits flush off that footpack with no overhang and their most quiet, BUT, apparently this set up will interfere with the moonroof when open (major bummer as I ride MTB and ski year round). They (Thule) used the word "may interfere with"....does any A4 Avant owners or others know of anyone with this set up that can confirm?? Otherwise, i will go with the setup like you have...which is still nice
    Joe
    Nov 03 2013
    Manchester, NH
    Quote Originally Posted by Itgb View Post
    Itgb - can you post picture of your avant with the Aerobars? I am contemplating which set up to get...thanks!
    Mar 18 2012
    San Diego
    Quote Originally Posted by skimtb27 View Post
    I don't have the aerobars on at the moment, but they look exactly like this: A4 Avant with Thule Aerobars
    Nov 03 2013
    Manchester, NH
    Thanks for the link, I saw that vid on youtube but wasnt completely sold it was what I wanted. A few weeks back I found the thread with the extensive review of the whispbars on a red avant and they looked sweet...flush edge and sunroof fully functional. Then I learned they were recalled for our avants :(.
    Established Member Two Rings Chelsea's Avatar
    Oct 14 2013
    West of Boston, MA
    So does the quietest Thule or Yakima Whispbar work on the Avant? I see differing opinions here.
    The fact that the roof doesn't open is mildly annoying, but not a big deal to me. I don't keep the bars on if I'm not hailing bikes or the box.
    Senior Member Three Rings vtwinjunkie's Avatar
    Aug 10 2013
    Various motorcycles
    NOVA
    Quote Originally Posted by Chelsea View Post
    Got a set of arb53's for sale if anyone is interested near new condition. $100 bucks plus shipping.
    Senior Member Two Rings sidkneeeeee's Avatar
    Jul 09 2013
    Fairfield, CA
    Quote Originally Posted by vtwinjunkie View Post
    Damn i need to sell mines too, sucks there was no update on this thread when i purchased the bars. Its kind of annoying me how much the bars hang.
    I think i will need to cut off the sides as stated by audibmi with the new specs. Im iffy though about cutting it need an electric saw and with non ferrous blade.
    2010 A4 2.0T P+ 6 Speed CPO / ECS Interior + License led lights / RS4 Grill + Honeycomb Fog cover / Sline Rims 255-35-19 Et43 / ECS Spacer 10mmF:12.5mmB / ECS Inlet hose + Dry Filter / B12 KIT (Bilsteins Shock / Eibach Springs) / 10mm+12mm spacers / Wrapped interior + Window trim + Jcodes / ECS Shortshifter / LED 3200K Yellow Fog / Coilpack, NGK plugs / GFB+ DV / Revo Stage2 / Eurocode HFC / Hotchkis F:R Sway Bars / ECS Transmission Mount Inserts/ Future Mods: Podi Boost Gauge ; 3.0 TDI IC
