Results 1 to 31 of 31
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    best oil among VW 502 00 and VW 504 00
    I'm thinking about going with a VW 502 00 approved Mobil 1 in 0W-40. I want to hear what other people on the board are doing. I'm in a mild climate where the temperature is never really under 50 degrees. I'm mostly concerned with heat dissipation, followed by high performance (maximum output) because I take the car out to the track quite a bit. I'm OK with changing it at 7500 if I've cheated myself a little bit on protection.
    Maintenance work
    Engine oil replacement interval : 10,000 miiles or 1 year
    Engine oil specifications: VW standard 502 00 or 504 00
    Engine oil filter replacement interval: at every oil change
    Engine oil change quantity (incl. filter): 6.5 liters (6.9 quarts)
    This is an interesting article on Porsches and oil:
    http://www.lnengineering.com/oil.html
    Jun 28 2012
    2012 Audi S4, 2011 Ford Fiesta, 1987 Porsche 928S4
    I think Pennzoil Ultra Euro 5W-40 Full Synthetic Motor Oil is being highly recommended on this forum. Search for oil test analysis threads here...
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    As the resident B6/B7 S4 oil guru, I'll weigh in.
    Mobil 1 0w40 is hands-down one of the best VW 502/505 oils you will find. The specifications are untouchable by anything at that price point, and even by the boutique oils costing twice as much. For $5.50/qt it's hard to justify NOT using it.
    Just look at all the approvals it meets. It's a streetable race oil. Did you know that M1 0w40 is used straight from the bottle in several racing series?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Motul VW/Audi Specific (505.00, 505.01, 502) would be my first choice (only comes in 5W-40). After that there are several that I would consider (Penzoil Ultra, Castrol Euro, Redline, Mobil 1, etc.). I don't see any real issue running 0W-40 based on where you live, but I also don't think there is any real advantage to doing so. Once you are at full operating temp, the difference between a 0W and 5W will be minimal.
    If you want the absolute best for racing, go with Motul 300V racing oil. It is the best you can buy, but you will need to go to more frequent changes....
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by jran76 View Post
    The thinking of "0w oils are only for cold weather" needs to die. It is not based in fact. Actually there are NUMEROUS 0wX oils that surpass their 5wX counterparts. Frankly, I think Motul Specific 502 is way overpriced and rather mediocre. I'd rather run M1 0w40.
    In general, asking what is the "best" oil is way too broad of a question. You need to tell us the following: Driving style? % highway/city? Any track days? Is the car stock? How often is the car driven? Lots of short trips? How often do you want to change the oil?
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by dparm View Post
    Can you point me to an oil analysis for the Motul specific oil when used on the 3.0 TFSI engine? I am about to take the plunge, but I have not been able to find any Blackstone analysis on this oil when used in the 3.0 TFSI engine (I don't really care about other engines....).
    I don't disagree with the first part at all. In no way was I saying there was some advantage in a 5W vs. 0W based on temp. My only point was I do not think there is a big advantage one way or the other in his case. I won't comment on anything else, because as you pointed out, there are way too many factors to debate this here....
    Pick an oil, and get it analyzed by Blackstone if you really want to know how it works in your car. From my personal experience on previous cars, I have had better results with Motul and Redline than Mobil 1 (along with awful results from Royal Purple). These are the only four oils I have personally had tested, and none were from my S4. From what I have seen on the B8 S4, Penzoil Ultra in 5W-40 seems to have the best results based on the limited testing that has been done.
    This thread covers the Blackstone testing done on the B8 S4 so far (still needs more test results):
    http://www.audizine.com/forum/showth...ght=Blackstone
    If you do get your oil tested by Blackstone, please update the above thread. I am at my second oil change and will be switching to the Motul, so hopefully I will have some real results on the Motul in the next 6 months.
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    What would someone who drives short trips look for? A 5w for higher thickness when cold (since the oil may not reach full operating temp)? I have Motul X-Cess 8100 in my garage from my B6 S4 still. I am a ways away from my next change on the new B8 S4 but I had just planned on using that.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Oct 20 2008
    I have been using Redline 5w-40 since I got my car. Used it on my last GTI, which eliminated my oil consumption completely.
    "I know it won't create actual downforce at 125 MPH. I know it does make the S4 more stable." - westwest888
    "It doesn't say anywhere in the rule book that a dog can't drive autocross" - westwest888
    "It would be easier if we just accepted my OP as fact in the Audizine sticky wiki. " -westwest888
    Apr 24 2009
    Frisco, TX
    jran, I've not seen any analyses of the Specific 502 or Specific 504 on the 3.0TFSI. It will work just fine, though for that much money I don't think you'll see any difference versus the store-bought oils.
    The 0w oils almost always provide an advantage of higher viscosity indexes, which equates to better startup pumping & flow. Remember how they scare you with things like "40% of all engine wear occurs at startup"? There is some truth in that, and we want an oil that flows and pumps very quickly when the motor is cranked over.
    I don't really stick with a single brand. I have no allegiance to a particular lubricant company. I buy the oils that have proven records. And believe me, I have gotten tons of UOAs from Blackstone in my B6 S4 -- both at the "halfway" point and when changed. A common mistake is that people get too fixated on a single brand, oil chemistry, or specification. They think esters are the ultimate in oil. Or they think they need a very specific HTHS value. Or they seem to think that Redline is the best oil ever.
    Every oil is different. Every motor is different. Every driver is different. Get UOAs (and VOAs) from a lab and find what works best for your scenario, as you said.
    As an aside, the B6/B7 S4 guys loved all the Liqui-Moly (Lubro-Moly in the US) oils. The UOAs were always mediocre in the 4.2L V8. No matter what I said, people still seemed to think it was an amazing oil. My UOAs on other oils always showed lower wear, less viscosity loss, higher flash points, and better TBN retention. So I think there will always be people who are not objective about this decision.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Akatsuki... View Post
    Try their 0w40. Far better oil.
    Their 5w40 is WAY too thick (HTHS 4.6). I would argue that the 0w40 is a bit too heavy too (HTHS 4.0).
    Much better: mix the 0w30 and 0w40 in a 1:1 ratio. You'll keep the super-high VI and get HTHS around 3.6, which is perfect.
    Senior Member Two Rings QSonx's Avatar
    Jan 31 2011
    2013 Scion FR-S, 2016 Audi Q3 Prestige
    Olathe, KS
    Motul 300V Power 5W40 :) is what I use... But only for track season and have to change it more often.
    But I use Motul Specific normally.
    2011 Audi S4 Premium+ Bang and Olufsen | Sport Diff | Nav | Apr Carbonio Stage I/II Intake | APR RSC Exhaust | APR ECU S2+ | APR Pulley | Vogtland Coil-Overs | Alu Kreuz | SPC Adjustable Control Arms | 19x9.5 VMR V710 | Michellin PSS | AWE Vent Boost Gauge
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Mobil 1 Euro 0W-40, German Castrol 0W-30, Pennzoil Ultra, Motul VW 502 Specific, and Amsoil Euro 5W-40 are all very good choices, but it ultimately depends on your driving style and change interval. I got Audicare free when I bought my car, and my dealer uses Castrol Syntec 5W-40. I get my regular services done at the dealership but change myself halfway through the 10k interval and thus far have put in Mobil 1 0W-40 because of my climate (Florida) and it is available locally. After my Audicare is up, I'll likely change it myself at 7500mi using either Mobil 1, Pennzoil, or Amsoil. I could probably stretch to 10000mi with any of those oils but why risk it? It's cheap insurance.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Apr 24 2009
    Frisco, TX
    I would not base my oil decision on what the dealer uses. They're buying whatever is cheapest but meeting VW specs.
    Also, VAG is allied with Castrol for OEM oil fill. It's not because Castrol is best, it's because Castrol outbid everyone else.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by QSonx View Post
    Why do you change the 300V more often? Do the analyses show it breaking down under track use? I used to run 300V 5w30 in my B6 S4 and even after track days it was still within grade and not contaminated.
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    The same is true of Pennzoil Ultra Euro 5W-40.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Stereodude View Post
    I don't doubt it. I still consider M1 0w40 to be superior to PU 5w40 though it's still a good oil. Pennzoil's biggest problem is they make good stuff like PU 5w40 and even 0w40, but they don't sell it in B&M stores.
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    Here is my oil analysis and testing thread for the 3.0 TFSI. I've tried several oils and have settled in with P Ultra 5w40. It's actually tested better than AMSoil Euro in my car. I've going to 11,000 miles on this OCI to see how it does. I'm at 73,000+ miles right now. Engine is running great. Not needing to add any oil.
    http://www.audizine.com/forum/showth...?highlight=oil
    Some people have had experience with oil shearing on viscosity stretched oils like M one 0w40. It's not common but there are dozens of reports at BITOG forum. I like the M one 0w40. It's an excellent oil.
    To me I would say the 4 best oils for the 3.0 TFSI would be P Ultra Euro 5w40, Amsoil Euro 5w40, Mobile one 0w40 then German Castrol 0w30. But we are really splitting hairs between these 4 oils. My wifes GTI burns more oil with the German Castrol compared to using AMSoil which is what I usually run in her car.
    That's my .02...love oil discussion threads!!!
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Apr 21 2010
    Florida
    Oh I agree with the notion of not basing it on what the dealer uses. That's why I do in between changes at 5000. I wouldn't dare run 10k on Syntec, but for a 5k run of mostly commuting it will do fine. However, the factory fill is Fuchs, not Castrol for our cars.
    Apr 24 2009
    Frisco, TX
    German Castrol is not what it used to be. Actually, it's exactly what it used to be....Castrol has not changed that oil for years, and it's now been surpassed by tons of other readily available oils. Shame.
    The B6/B7 cars had Castrol Magnatec as factory fill, so it may have changed.
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    This question is directed to those who consider their selves Oil Guru's :-)
    I ran my car to around 6000 miles before I went into the dealership to have my first Audi Care service appointment. I provided them the Motul Specific that I had purchased off of APR. My questions is
    Is waiting to 15000 miles for my next service appointment too long?
    I am planning on using PU 5w40 for my next few changes.
    Should I change my oil now? I am sitting at around 11500 miles, or is that over kill as I would also change it at 15000?
    2012 S4 - DSG B8 - [email protected]
    Apr 24 2009
    Frisco, TX
    That is WAY too long. The change interval is 10k, which is probably pushing it given how we all drive these things.
    Nov 09 2011
    Michigan
    I think you Misread, I changed at 6125 around that mark. My question was, should I change right now sitting at 11500(+5375 Miles) OR would it be OK to wait until 15000(+8875 Miles)
    At 6125 I used Motul Specific purchased from APR.
    I am planning on using PU 5w 40 from here on out.
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by Jones2012s4 View Post
    You're probably fine going to 15,000 unless the car is constantly short-tripped or on the track every weekend.
    Also, are you getting PU 5w40 locally? I hope you aren't paying more than $7-8/qt for it...
    Jan 31 2011
    Olathe, KS
    More often as in after 3000-4000 miles instead of 5000-6000 miles. Reason behind my decision was based on speaking with some other Motul users at the track. I should of said I plan to change it more often cause I honestly haven't changed it once yet since putting in the 300V but I don't drive too often. Changing the oil isn't really a chore to me so honestly if Oil was cheaper I would probably change it monthly, lol.
    Apr 24 2009
    Frisco, TX
    But why remove perfectly good oil? I suggest you pay the $50 for an analysis and see if it can stay in and even go longer. I don't see the value in changing oil so often, especially if it isn't contaminated or depleted.
    Nov 09 2011
    Michigan
    I'm going to pick it up off amazon 46-50$ for 6 qts so pretty much right in the middle of what you mentioned, unless you can recommend somewhere else.
    Apr 24 2009
    Frisco, TX
    I never bothered to research it, but that's still a lot of money for an oil that's going to perform identically to M1 0w40, SynPower 5w40, or Syntec 0w30 under typical use (all of which are <$6/qt).
    Nov 09 2011
    Michigan
    This is a good point you make, however. My babies worth the extra couple of dollars. :)
    Seriously though thank you for the advice! On a side note, since I changed my oil at 6125 with Motul Specific I have not had to refill. I also followed your typical no holding back break in method.
    Apr 24 2009
    Frisco, TX
    Fill with what you want, but PU 5w40 is not going to perform differently in service than the others I listed. The specs are actually below M1 0w40.
    If you do run it, get an analysis and see how it does in your motor.
    Veteran Member Four Rings essfour's Avatar
    Dec 03 2010
    Boston
    ^ Can you post an analysis of your results using M1 0W-40 in this motor? I find it difficult to believe that this oil, although very good, is as good as you think it is for our cars. I am not saying it is inferior oil, it is great. But it might not be as good as you think… Have you seen the blackstone results using PU 5W-40?
    2022 Daytona RS6
    2020 Alpine White X7 50i
    1987 E30 325ic 5spd
    2018 Tanzanite M3 ZCP - sold
    2013 Phantom Black RS5 w/ Alu Optic package - sold
    2011 S4 6MT Meteor Grey w/ Ti package - sold
    2008 A4 S_Line Avant 2.0T 6-speed - sold
    2006 A4 Sedan 6-speed - sold
    2001 A4 Sedan 5-speed - sold
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by essfour View Post
    I have not had my car long enough to do anything.
    Go look around on BobIsTheOilGuy to see all of the excellent analyses returned from a wide variety of motors on that oil. It is definitely "as good as [I] think". API SN, VI of 185, every friggin OEM approval you can think of, and a good HTHS-to-KV ratio. PU 5w40's specs are not nearly as impressive, it costs more, and is harder to get. Like I've said...run what you want as it's your car and your money.
