Originally Posted by
YnotS4
Been meaning to do this. I added the 034 front and rear end links on the stock sway bars. YES there is a difference the rear bar can do its job with out binding the rear there is a little less lean and the rear rotates just a hair better now that the bar can do its job. The OEM stuff is VERY flimsy!!! I could move the lower rubber bushing and bolt with very little pressure the movement was unbelievable. The front now has a little more bite on initial input and a little less lean with the stiffer bushings. There is no increase in NVH at all. Although I have not changed the bars, this upgrade was worth while. Speak with Jeremy @ 034 who took great care of me and provided great customer service.
Thanks Ynot!
I run the links on my B5 A4 as well, with a factory bar, and I was amazed at how much of an actual handling difference it made. Without even changing the bar, the car was able to rotate quicker and was far more stable. Makes you realize that a lot of people with upgraded rear sway-bars are not getting the full benefit of their upgrade since the factory end-links can flex so much.
The other nice thing about our adjustable links is that they allow you to keep the bar parallel to the ground after lowering your car; for the best most predictable performance, you want the bar to be parallel.
