Since going to APR stage 2 (please note other possible relevant mods in my signature) a few months ago the MIL warning light on my A4 has been appearing fairly frequently. I don't have any noticeable drivability issues. The first couple of times that the lamp came on I reset it but after the 2nd or 3rd reset I took it to the Audi dealer (Reeves in Tampa - I'm still under warrantee, they're aware of the mods and they still cover me). The Audi tech said that the MIL was caused by the oxygen sensor before the cat with internal electrical malfunction. They replaced the front heated oxygen sensor, road tested the car and gave me the all clear but after a few days the lamp started apearing again. I've reset it about six times since I took it to the dealer for the fix on July 11th. The VCDS scan that I did before going to the dealer was done on July 6th and it indicated only one engine malfunction (too rich at idle) but my July 22nd VCDS scan (10 days after the dealer service) came up with six errors (see below). Any suggestions? Thanks.
6 Faults Found:
4054 - Cylinder 1
P0301 00 [096] - Misfire Detected
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 77174 km
Date: 2012.07.11
Time: 18:07:45
4060 - Cylinder 3
P0303 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77174 km
Date: 2012.07.11
Time: 18:07:45
4063 - Cylinder 4
P0304 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77174 km
Date: 2012.07.11
Time: 18:07:45
4057 - Cylinder 2
P0302 00 [096] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77174 km
Date: 2012.07.11
Time: 18:07:45
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 77174 km
Date: 2012.07.11
Time: 18:07:14
4106 - Bank 1; System too Rich at Idle
P2188 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 78274 km
Date: 2012.07.21
Time: 15:48:30
Readiness: 0010 0001
