Results 1 to 4 of 4
    Aug 08 2012
    Finland
    Exclamation Audi A6 T FSI 2.0 Automatic gearbox problem.
    Hello
    I have Audi A6 2.0T FSI multitronic automatic gearbox gasoline Year 2006. The problem is that when I let the brake it doesn´t move forward untill i push a little gas. Then it goes forward but it jerk. The car has past 90 000 km and at 58000 km has been changed the oil in the gearbox so oil is OK. It jerks only when i let the brakes and push gas to go forward. It doesn´t jerk when i drive, only at the start. also it doesn't jerk when reverse. i was today at small service and they checked from the computer and it says all is OK and no problems found.
    I hope you understand my problem because i used google translator.
    So if anyone can tell me what could be the problem.
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by Grobar View Post
    Hello
    Kuulostaa minulle, jos jompikumpi vaihteistoöljy on alhainen tai sisäinen pumppu on maksukyvytön tai momentinmuunnin voi olla merkkejä epäonnistumisesta. Sinun pitäisi heittää hiukan kun ottaa jalka pois kaasua.
    Goolge translated to finnish: Sounds to me as if either the transmission fluid is low, or internal pump is failing, or the torque converter may be showing signs of failure. You should roll slightly when you take your foot off the gas.
    '09 C6.5 A6
    Aug 08 2012
    Finland
    Thank you for answer! i was today in Audi center and the guy from audi service test my car and told me that it looks like there is oil too low or there is too much. well i have next week reserved time so they will check what is it and they will fix it.
    Jul 17 2011
    Sin City, USA
    Se olisi hyvä, jos se on neste-ongelma. Helppo korjata. Pidä meidät lähetetty!
    Translated:
    That would be good if it is a fluid level issue. Easy fix. Keep us posted!
    '09 C6.5 A6
