Results 1 to 7 of 7
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Special tool for getting cables through grommets?
    Wondering if anyone can recommend a special tool for getting electrical cables through grommets such as this:
    In some instances one end of the grommet can not be removed from the car body (such as in some Avants/estates/wagons) which can make it very difficult to feed cables through.
    I've used methods such as wrapping some electrical tape around a flat blade screwdriver with the cable and feeding it through, but I'm wondering if there is a better way or a tool specifically for the job?
    Nov 07 2005
    RS6, M5
    Can a mod please delete the spam above?
    Sep 02 2008
    Boonies VA
    The best special tool I know of is one of these:
    Cut it and straighten it out, then tape your wire to one end and fish it through the grommet. Because the hanger is somewhat bendable you can manipulate it through easy enough, I used one most recently getting speaker wires into the front and rear doors.
    White Wagon
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    Quote Originally Posted by Alister View Post
    Done
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
    Jul 12 2004
    Quote Originally Posted by naiku View Post
    I usually use a long zip tie. While the wire hanger works it can pierce the shielding of wire.
    Sep 02 2008
    Boonies VA
    The zip tie is probably better as well in that I imagine its more flexible than the wire hanger. I will have to give that a try next time I am fishing wires through a door (which will probably be this weekend).
    White Wagon
    Feb 07 2008
    The boonies, near Seattle
    Buy a pack of the long zip ties from home depot. Cut the head off then tape whatever cabling you're running to it and pull it through. If its really tight, you can use something like windex as a lube to get it through.
    -dre
