Results 1 to 17 of 17
    Nov 30 2008
    05 S4, 02 A4
    Raleigh, NC
    Broke upper radiator elbow. Possible work around?
    I upgraded to the JHM ported intake manifold (YAAY!) and while installing last night, in the dark, and rain...I managed to break the small hose connector on the upper radiator hose elbow.
    If you need a visual:
    So, those not familiar with the hose that connects to this, it sort of Y-splits and one end goes to the intake manifold heater, and the other goes to the reservoir.
    Anyhow, to stop the leak I capped the broken connector with a screw, removed that hose and the Y-split completely, and connected the other end of the manifold heater directly to the reservoir. Ran the car up to temp, and things seemed to be ok. Can anyone foresee that being an issue to leave it that way? I know it seems dumb to not just buy the $12 part and do it sort of the right way. Doing it this way though eliminates a hose, and bypasses that manifold heater without the need for the strait through barb.
    Kool-aid red B6 S4 Avant. JHM NAWZZZ kit, JHM headers, FI cat-back, JHM tune, JHM IM, LWCP, LW rotors.
    Senior Member Three Rings 04 S4's Avatar
    Nov 01 2011
    2005 Ford E250 Work van
    Bonney Lake, WA
    linky no worky
    2004 S4 (Tip) - Dolphin Grey metalic Traded 4/3/13
    2009 Q7 Prestige S-line - Daytona Grey
    Sep 13 2008
    Western Chicago Burbs
    Lol I can foresee a big issue.
    That's the hose that sends excess coolant to the expansion tank when the coolant expands as it gets hot. Don't drive the car like that at all.
    Nov 30 2008
    05 S4, 02 A4
    Raleigh, NC
    Quote Originally Posted by B6JoeS4 View Post
    Thanks Joe, exactly what I was looking for.
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Exactly, it is a pretty important hose. Also connects the coolant feed through the intake manifold on the RS4 so it has coolant flowing at all times.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I have broken a bunch of those elbows. It would be great if I could find a metal pipe with a small y fitting that came off to eliminate that elbow. You could get rid of the stupid factory spring clamps and using screw clamps to hold the rubber lines on.
    Veteran Member Three Rings Rirruto's Avatar
    Dec 09 2009
    Ocala
    That sucks man. Mine just broke on Sunday. I literally popped the hood and barely moved the hose and the little nipple part sheared right off, spraying coolant everywhere. I also don't understand why a metal part couldn't be there.
    -Bryan
    2005 Dolphin Gray S4
    Sep 13 2008
    I can't blame Audi for using the plastic part there. They have used similar parts on older cars with no issues. Someone engineer just goofed
    Veteran Member Three Rings Dcass08's Avatar
    Jul 21 2011
    Rochester NH
    It'll be fine, mine broke as well. I plugged both ends and have been driving it in this 98 degree weather with no issues. The new one will be here tomorrow.
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    Lol how much coolant comes out when replacing that elbow or is my whole system going to expell all of its coolant leaving me to burp it
    Kris
    Rest In Peace Four Rings
    Oct 14 2012
    Upstate NY
    If you can find a radiator repair shop they have small metal sleeves that will go through the broken elbow and piece that broke to reinforce it. Used in conjunction with some good epoxy and the repair will outlast the car.
    Dec 28 2011
    North Texas
    I broke the nipple there is no repairing ill buy new elbow just was curious how much coolant I am about to spill in my garage.
    Kris
    Dec 28 2011
    North Texas
    Should I just dump the radiator to keep mess at minimum?
    Kris
    Veteran Member Four Rings nnnick's Avatar
    Nov 01 2005
    2006 S4 6MT
    La Jolla, CA
    All I gotta say is f**k that elbow. I've broken it too. Very brittle and easy to do :(
    I swear parts like that are why I'm convinced Audi intentionally designed "booby traps" to prevent people from working on the cars themselves...
    Current: 08 R8 6MT, 14 Cayenne GTS, 98 Saleen XP8
    Past: B7 RS4, '12 Audi TTRS BT Build | 2006 Audi S4 HPDE Build | 2006 Audi A4
    Visit my blog: NicksCarBlog.com
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by nnnick View Post
    Just wait till you see a BMW cooling system... You thought the Audi was bad, imagine almost guaranteed failure every 40-50k miles.
    Senior Member Two Rings blaelock's Avatar
    Sep 07 2013
    San Diego
    I broke that same elbow three months ago. I actually also jerked another coolant line in the process and had to replace a whole rats nest of cooling hoses. Wasn't cheap.
    2012 BMW 135i Dinan S2
    1985 BMW 325e
    2003 Honda Civic EX
    2011 BMW 135i 6MT
    1999 BMW M3 - Techno Violet Metallic on Mulberry
    2005 B6 S4 quattro Sedan 6MT Light Silver Metallic on Ebony Recaro Leather
    2004 BMW E46 330i Bilstein/Eibach B12 Pro Plus Suspension & Sway Bars
    1986 BMW E28 535i
    Sep 07 2013
    San Diego
    Quote Originally Posted by BenSti View Post
    I can personally attest to this. A BMW I owned under warranty experienced a failure within that range. I've made it a point to replace the cooling system on any used BMW (or european vehicle) I own every 50-75k depending on the condition of the parts. The nature of the design in combination with the brittle, old plastic is a nothing short of a time bomb.
    1985 BMW 325e
    2003 Honda Civic EX
    2011 BMW 135i 6MT
    1986 BMW E28 535i
