Results 1 to 13 of 13
    Established Member Two Rings 1FlipA5's Avatar
    Jul 08 2011
    North Jersey
    20x10.5s with 285/30/20 tires all around on H&R sport springs, doable w/o rolling?
    Hey guys,
    I have been talking with Incurve wheels and they have given me a great opportunity to go 10.5s deep concave all around with my IC-M7s I currently have 20x9F 245/35/20 and 20x10.5R 285/30/20 lowered H&R sport springs with no rubbing aside from high speed bumps/potholes which is expected... My current set up is only about 5 months old with less than 4k miles so I would hate to get all new tires again. I was hoping to stay 285/30/20 all around so I would only have to worry about 2 tires.
    I've searched the forum and I know a couple people have done it like John P., Victorious, and Timmy. One rolled his fender with coils and another had no rubbing at all with H&R OE springs. As a medium, between the two what do you guys think?
    Thanks in advance
    2011 A5 2.0T | 6MT | Premium Plus | B&O | Ibis White/Black/Alu Inlays
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Clint,
    It's doable, as you know, but it really depends on few things:
    1) the tire itself- some 285s are wider than others, so that's where the largest concern is. If anything, a fender roll isn't that big of a deal.. I ended up rolling my fronts anyway. I borrowed one and it took about 20-30 mins per side.
    2) suspension- the springs aren't that low, so I think you should be okay due to your springs, which are a bit conservative up front. The only thing I'm curious about is if that will give you less negative camber up front making it more difficult to 'tuck'
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Jul 08 2011
    North Jersey
    Quote Originally Posted by staticuxo View Post
    Clint,
    Chach thanks for the info! Im gonna try getting a similar set of tires that I have now, the Yokohama S. Drives as they seem to be on the thinner side...any experience with the Hankook 285/30/20 tire? Any idea where to get a fender roller?
    Its funny, but last time I took the A5 to the dealer they mistakenly rotated my current set up so they put the rears up front. It seemed like there was some room to spare still and it looked damn good! I didn't get to inspect it more thoroughly or drive it though as I was too distracted by the stupidity of the mechanics....cant believe they didn't notice the staggered setup. I told them to switch it as soon as I saw the car.
    Stage 2 Banner Advertiser Four Rings Alex@TAG's Avatar
    Nov 15 2011
    ABT RS5-R, SQ5, 488 Pista
    San Diego, CA
    It is duable... we have done it before but it takes a bit of massaging of the fender as well as the right offset of the wheels to make them happen.
    To be safe, i would run a 275/30/20.... Let us know if you need to get some special pricing on tires...
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    AUTHORIZED DEALER: HRE Wheels || FlowForm || Vossen || ABT || TechArt || AWE Tuning || APR || KW Suspension || Milltek || BBS || Brembo || Michelin & more!
    Sep 02 2005
    Montreal
    285 is getting pretty extreme for front tires, not even supercars have such wide front tires, it numbs the steering response, road feedback suffers and doesn't track straight on uneven surfaces. It's not a good idea, unless you're only going for the "look" of big fat tires, as it certainly doesn't improve perfornace and handling.
    Jul 08 2011
    North Jersey
    Alex the offset is et 28
    Appreciate the feedback! I was thinking of doing a test fit/drive by switching my rears and fronts temporarily if no1 sees a problem with this...
    I would have gone 275/30/20 all around if I had a clean slate but unfortunately this is impulse so I have to work with what I have. I understand that theses tires may not be the best for performance/handling but I do not track the car, its not my daily driver, and I don't drive aggressively. Imo I also wouldn't exactly consider 285/30 on 20x10.5 a big fat tire, at least with Yokohamas and Hankooks. Wouldn't mind that extra "meat" for the roads here in the tristate area either.
    Sep 28 2010
    NW NC / DE
    Clint, what is the offset on the 10.5's?
    Jul 08 2011
    North Jersey
    edited my post Mop
    Sep 28 2010
    NW NC / DE
    Et28, hmmm. I run Et25 on Michelin SS (they run very wide) and am much lower than you are with no rub. You can make it work with little effort (if it does not as is), pull the trigger. Will look damn good
    Jan 18 2012
    I know this is an old thread but I'm planning to run the vossen 20x10.5 all 4 corners with the Michelin SS as well and I am on the h&r OE springs... So could I pull off a 285 30 20 without rubbing ? The front really concerns me.... Or should i just run the 275 I mean how big is the difference really ? What's everyone's thoughts ? I don't just cruse I tend to drive pretty hard with even the occasional track day twice a year ... Any input not already posted above would be great!
    May 13 2011
    san diego california
    my next set up is 20x11 all around with 295/25/20
    et 28
    -1.5 camber all around
    Jan 18 2012
    cool haha
    May 07 2012
    2000 accord coupe, jdm f20b, t3/t4 turbo
    Hudson Valley NY
    Im putting some 20x10 ET20 with Yokohama S-Drive 275/35/20's on tomorrow. A5 S line, stock suspension. Not quite what your looking at, but close to your potential 285's. I'll let you know if I have any fitment issues but from what I have read, I should be fine.
