Results 1 to 11 of 11
    Junior Member Two Rings Jayboom05's Avatar
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Lightbulb My dream A5 BT build
    I live in the USA
    Well I will have an A5 2.0t manual by Jan/Feb 2013
    I'm a newbie to this whole forum thing, but you guy saved me $$$$ working on my 06 GLI with all the DIYs in this forum and some VW forums.
    Really waiting to see the results from IRC BT A5 build.
    Judging by the online search for the used A5, most people buy this car with the 6 speed automatic. This is probably why no tuning company made a kit bigger than the K04 upgrade because the auto tranny would not hold up to the higher power levels.
    That means no market for a stage 3/3+/4 kit for the b8 (yet I hope still)
    So I went online window shopping and this is what I came up with,
    *Please school me on realistic labor cost, where I could get cheaper parts etc*
    www.kmdtuning.com
    (Atp Turbo GT3076R-WG 500hp)
    Turbo & Manifold 2240.00
    w/ oil & Coolant lines
    w/ compressor inlet elbow
    w/o high flow compressor out
    Air Ratio .64
    Wastegate 1.5 bar (22psi)
    (AWE Tuning FMIC)
    Intercooler 995.00
    Shipping 55.62
    Total 3290.62
    www.ecstuning.com
    (K&N)
    Cold Air Intake 252.95
    Valve Cover Gasket 11.33
    Intake Manifold Gasket 19.03
    Exhaust Manifold Gasket 6.00
    Cylinder Head Gasket 66.45
    Valve Cover Gasket Sealant 94.10
    Oil Pan Gasket Silicon Sealant 37.48
    O-Ring kit(4) 39.60
    Shipping 12.43
    Total 563.45
    www.intengineering.com
    (Intergrated Engineering)
    Connecting rods 499.99
    added rifle Drilling
    (Mahle)
    Pistons 659.99
    83mm Bore 9:1 CR
    Shipping 24.26
    Total 1184.24
    www.unitronic-chipped.com
    (unitronic 3076r tfsi tune)
    Software 740.00
    labor 2hrs 180.00
    Tax 7.5% 69.00
    Total 989.00
    www.carsandconcepts.com
    Rod & piston install
    Total(Quoted) ~2000.00
    www.dxdracingclutches.com
    (DXD)
    modified factory clutch disc ~675.00
    --install same time with rod/piston--
    --estimated labor added 3hr ~270.00
    Everything else I can do my self.
    I could shop around look for cheapest used parts (excluding turbo/manifold,rod/piston,clutch)
    Total price for after everything is installed 8972.31
    **cheapest found August 1, 2012**
    Dealer in PALM SPRINGS, FL
    2010 Audi A5 2.0T Premium Manual- $29,999.00
    RS5(stock)
    4.2fsi...R8 variant
    444hp
    3950lbs
    1hp per 8.89lbs
    Rs5(possible APR SC kit) *based off what the RS4 makes*
    590+hp
    3950lbs
    1hp per 6.69lbs
    S5(APR SC)
    4.2fsi
    537hp
    3891lbs
    1hp per 7.24lbs
    S5(SC APR ECU w/pulley upgrade)
    3.0tfsi
    475hp
    3858lbs
    1hp per 8.1lbs
    A5(MY Dream BT)
    2.0tfsi
    470hp (estmated from what ive seen on the tsi dynos in gti's and scirocco's with GT3076r's similar upgrades)
    3645lbs
    1hp per 7.75 lbs
    and still manage 30+ mpg/hwy if I don't put my foot into it LOL
    "you'll be ok"
    Veteran Member Three Rings aLTTP's Avatar
    May 09 2011
    Rice Patty
    interesting read. you've done your hw
    Will toil for sustenance
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Wow great home work. Especially for a new forum user. Welcome to AZ.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Thanks man, now just saving and waiting till 2013. Hopefully by then a lot more people are off their leases ready to trade in and prices go down.
    "you'll be ok"
    Active Member Four Rings DinB's Avatar
    Apr 20 2012
    O
    How are you gonna get 470 hp out of the 2.0 engine?
    SOLD Ibis White RS5
    Factory: Nav., B&O, Sport exhaust, and Steel mesh/piano black trim
    Aftermarket: 20" Ti OEM wheels, 20% tint, v8 badges, dynamat in the rear parcel, Infinity Basslink sub, OEM silver tips, OEM alu-optic)
    To Do: (2014: KW HAS springs, spacers)
    "When the cat man speaks, you listen!" - Mops
    Established Member Two Rings sleeper's Avatar
    Dec 23 2009
    salt lake city UT
    too bad the world ends in 2012 :( Welcome to the forums though. In my experience having owned several big turbo cars i can say this. Do it right or do it twice. Spend the extra cash, long run you will save your sanity and alot of money.
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Quote Originally Posted by DinB View Post
    The same way Apr got 451hp 93oct and 501 100oct out of the 2.0 TSI
    http://www.goapr.com/products/stage3...tsi_trans.html
    Apr tunes are very conservative, and once Bosch releases the bigger fuel injectors for the TSI/TFSI so that everyone can buy, I'm sure I will be able to reach the power levels that all the 2.0 FSI engines are putting out with similar upgrades.
    Apr kits uses a gt3071r, I'm going to buy the gt3076r so I know at least 450~470 at the crank. I guess I could add a W/M kit to it too. Do feel that's unrealistic?
    "you'll be ok"
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Quote Originally Posted by sleeper View Post
    Thanks for the advice, the internals and clutch will be done by a shop, everything else bolts right on. Do you think 470hp at the crank is a reasonable estimate of what I should be making from the parts you see?
    "you'll be ok"
    Feb 04 2010
    Jeddah, Saudi Arabia
    this is gonna be great!
    Instagram: @TheDapperDriver
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Boy was i dreaming back then lol 😂...well since then the (payed off) 06 gli was totaled by Lil bro and ended up buying a '12 GLI...wasnt going to be able to afford a '13 A5 (which grew on me and I had to have the face lift)........So in two years when the GLI is payed off maybe APR will finally have their b8 kit released and I may buy an A5 post my build....or put a large sum down on a used 08 r8 50k range (in two years) and just enjoy driving that for a few years :) but I def won't be able to afford any upgrades on that.
    Sent from my HTC 10 using Tapatalk
    "you'll be ok"
    May 06 2012
    2010 Q5 2.0tfsi
    Tampa Florida
    Quote Originally Posted by Jayboom05 View Post
    Boy was i dreaming back then lol ...well since then the (payed off) 06 gli was totaled by Lil bro and ended up buying a '12 GLI...wasnt going to be able to afford a '13 A5 (which grew on me and I had to have the face lift)........So in two years when the GLI is payed off maybe APR will finally have their b8 kit released and I may buy an A5 post my build....or put a large sum down on a used 08 r8 50k range (in two years) and just enjoy driving that for a few years :) but I def won't be able to afford any upgrades on that.
    A guy named @outspin on here beat me to it....I ended up getting a '13 S5
    "you'll be ok"
