Results 1 to 8 of 8
    Mar 26 2012
    Upstate NY
    Boost leak Test, Air coming out of the dipstick tube
    is it bad to have air coming out of the dipstick when i do my boost leak test?
    its not alot but it is coming out, I also can hear some liquid (oil?) bubbling when applying pressure
    I've got P0299 and I think my car is in limp mode.
    Veteran Member Three Rings cdn20valve's Avatar
    Oct 09 2007
    B6 A4 Avant
    North Toronto
    Quote Originally Posted by krawa View Post
    You need to pinch the crankcase breather hose at the TIP.
    Mar 26 2012
    Upstate NY
    Quote Originally Posted by cdn20valve View Post
    I disconnected hose that going to "pancake valve" and plug the hole in TIP before test
    Jun 30 2008
    Erie, Pennsylvania
    This happens even with the oil cap off? You should *always* remove the oil cap when doing a pressure test as insurance against pressurizing the crankcase.
    Anyway, oil bubbling and such is normal when you are applying the pressure through the turbo. The boost pressure leaks through the CHRA into the oil lines and makes that noise. It seems to happen more on turbos with lots of miles. Newer ones seem to hold the pressure better. If it leaks so much that the test isn't working, you can do the test at the lower intercooler connection. Do the pressure test post-turbo.
    Mar 26 2012
    Upstate NY
    walky_talky20 Thanks,
    some great points here, I did my test with the oil cap on, oops
    I was suspecting turbo as the reason for underboost code, but I don't have any smoke from exhaust.
    EDIT:
    135K miles, turbo seems to be original.
    Apr 23 2012
    statesboro ga
    have you driven thae car yet. i wanna say if you boost leak test with the oil cap on it will cause smoke out the exhaust the next start up.
    Jun 30 2008
    Erie, Pennsylvania
    I should add that just because it leaks pressure that way during a test doesn't necessarily say anything bad about the turbo. The way the pressure test is done (by pressurizing the turbo inlet) is not the way it works in operation. It can bleed off pressure into the oil lines but still work just fine.
    Mar 26 2012
    Upstate NY
    Quote Originally Posted by bagged00 View Post
    drove the car right after with no smoke or any other issues
    the turbo has shaft play and make dentist drill noise, so it's not in the best shape anyways.
