Results 1 to 6 of 6
    Active Member Two Rings theprocess's Avatar
    Jun 06 2012
    Hogtown, CA
    Who makes the oem air filters for Audi?
    Hengst? Mann? Mahle? Some other company?
    Time for a new air filter and I've decided not to use a k&n or other serviceable filters. The media looks much more robust in the oem/aftermarket filters.
    '07 S4 Sprint Blue Pearl
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Probably Bosch. Idk if they make air filters?? I would recommend buying a couple of air filters on rockauto.com
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Senior Member Four Rings
    Aug 11 2011
    OEM is either Mann or Mahle.
    Sep 13 2008
    Western Chicago Burbs
    Just like the oil filters, every single filter you can get for this car is exactly the same. Pick the cheapest one
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    Quote Originally Posted by B6JoeS4 View Post
    Bingo.
    Audi has specifications they must be made to, so there is no difference. I would not obsess over which one you get.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Jun 06 2012
    Hogtown, CA
    Good to know! Thanks for the info.
