The compressor itself is quite simple to remove, 3 bolts and two t-30 torx bolts for the AC lines. The high and low pressure lines are a bit trickier but still not too bad. You have to put the car into ''service mode'' (pull front bumper out a few inches) to get the condensor and high pressure line out. It also helps for the line to the receiver dryer. The dryer itself is fairly easy to remove, just 2 bolts plus 2 t30 torx bolts for the lines. The lines going from the dryer to inside the car are also very straight forward. Just remove the airbox assembly which takes about 2 minutes, and unbolt the allen type retainers for the lines, and unbolt another T30 torx at the evaporator. Sorry for no pictures, my iphone camera is dead lol.
For those interested in this you could probably just remove the compressor itself but I figued why leave all the hoses and condensor and such for nothing. It really removes quite a bit of clutter under the hood, and Now I have much more room for a fmic :D Finding the correct lenght belt was a bit of a bitch, more trial and error than anything, but finally stopped on a 450K6 from Dayco. Perfect fit , very stiff and not to hard to get on. A 445 would probably work too but would be quite a bit harder to get on there. I searched the forums for a while looking for this info and couldn't find it so I figure maybe some others will appreciate it!
Happy wrenching!
