Results 1 to 9 of 9
    Jul 08 2008
    04 A4 1.8T
    UK/HK
    Headliner repair - which glue to fix sag?
    I need to repair my headliner as its sagging so much it's rubbing against my head!
    Will take out it to make job easier and clean off all the old orange foam. I bought some high temp resistance headliner spray. The spray is web like so it will leave small gaps on cloth. Wondering if this is the best way to get max hold or apply some high temp glue by spreading it across complete area?
    Anyone done this repair yet and have tips for best glue and method to apply?
    Many thanks!
    J
    Established Member Two Rings jhjeff's Avatar
    Jan 09 2016
    2005 A4 Avant 6MT 1.8T, 08' Toyota Tundra, 88' FJ62
    Jackson, WY
    Try heating up the area with a clothing steamer (if u have access to one), if not try a hair dryer and a super light spray of water. Idea is to heat up the glue that's in the headliner foam and tighten the material. Then use a soft paint roller to smooth out/re-attach the material. Will need to finesse it a bit.
    Good luck!
    Veteran Member Three Rings JAudi23's Avatar
    Oct 31 2013
    2003 Audi A4 3.0 Quattro 2004 Audi A4 Avant 1.8T FWD & 2000 Kawasaki Ninja ZX-6R
    Milton, ON, CA
    I need to attempt this as well, and we do have a good clothes steamer (that we've never used). My headliner is only sagging over the rear seats. I was hoping to not have to actually remove the headliner from the car to do the repair, can the steamer and soft paint roller method be used in the car as installed rather then removing the headliner and doing it on a bench?
    2003 Audi A4 3.0 Quattro, Brilliant Black
    Custom 12V USB Socket | ProClip Mount | Curt Mftg Hitch | Thinkware F800Pro Dashcam
    Retrofits:B7 Center Console Swap | RNS-E
    SOLD - 2004 Audi A4 Avant 1.8T FrontTrak, Light Silver Metallic
    Nov 28 2009
    Winchester,va,east coast
    my rear headliner is sagging and has actually came loose around the rear light, so for now I've bought some clear tacks that spin in to hold it up. I'm debating on doing a full s4 black headliner and pillars install, or just remove it and lay down new fabric. I'm stuck in a debate on if I wanna take my usp to show level or just continue to have a clean DD and wait to buy a newer model Audi. I kinda wanna save the B6 and make it show worthy.... I see so many clean B6's in the picture thread that it makes me wanna go crazy buying coilovers or bags, wheels, wrap the body, bumpers etc...
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    Quote Originally Posted by jhjeff View Post
    Good luck!
    is this BS or does it really work? ive never heard of doing this but need to soon
    Oct 31 2013
    Milton, ON, CA
    Quote Originally Posted by alien_brain View Post
    Well I can tell you, my original headliner is sagging across both rear seats and it only got worse by touching it and trying to spray some 3M glue in behind. If you're not careful the glue can even seep through the cloth.
    I did get a good tight replacement headliner which I have not yet installed. However, I messed up when trying to clean some stain marks on it with an upholstery cleaner as now the passenger side came loose a little in the concave area above the head.
    I'm going to try to fix it again with some heat and gentle sustained pressure. The headliner is stretched over the upward curve and is difficult to keep in contact with the inward bulging shape.
    I would not try to do this in the car as gravity works against you, unless of course your car is flipped on its roof.
    Sent from my SM-G965W using Audizine mobile app
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    And if your car was flipped on its roof, the headliner wouldn't be sagging anymore. It's practically win win.
    I think our headliners are too light colored for any glue fix. One guy on youtube affixed a syringe to an aerosol tip to inject new adhesive, but warned that it shows stains on light colors.
    Best fix is to pull it out and redo it with Alcantara or something cheaper. Then I can finally have true all-black interior.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Based on this video it seems just like every other headliner I have seen where the fabric has seperated from foam. On other cars my experience was once the foam is coming apart it's hard to reglue it well enough to have a fix that lasts, better of getting a new piece of material. I sourced mine from a local upholstery shop, I used 3M adhesive (my Dodge Raider) and it held up for 12 years. At 13 years it's doing the same thing the oem stuff did at the same age.
    https://www.audizine.com/forum/showt...dliner-Express
    Veteran Member Three Rings PSI NRG's Avatar
    Feb 24 2008
    I've wanted to do my headliner since its starting to sag with some grey suede, but it looks like a bitch to remove. This kid had that liner out in no time. Maybe its because he doesn't have a sunroof (which my car does) and it requires a bunch more steps.
