Now I'm all for proper fluids and given my shitty transmission has a failing Torque Converter/Valve Body I'm seriously considering changing the ATF and filter (using Phil's excellent DIY
Now I've been an avid proponent of only using the OEM fluids on these Tiptronics (the 09L at least) as they appear to be VERY fragile and finicky about fluids, fluid levels, etc but this D6 fluid has me intrigued.
Now I looked into the Redline D6 and its Dexron VI based fluid (hence the D6) and on their product page it 6HP26 as a compatible transmission. Now I know thats not the same as the 6HP19 that we have, but would it work. LINK
Disclaimer, I'm not going to be the guinea pig for this, at the moment this is more of a thought experiment/discussion. Also if I'm mistaken about the transmission types, chime in, as I'm not 100% positive we have the 6hp19A rather than the 6HP26 as I keep reading differing info.
As far as part numbers, looking at ETKA all our transmissions take the G060162A2 fluid, which was confirmed (sorta) by my local dealer who said he didn't have a part number but that it said ATF Green.
Thoughts are appreciated.
