Hey guys.
So I bought my B6 and it came with a APR st1 tune and the stock DV.
I decided my first upgrades would be
-Forge 008 DV
-Electronic Boost Gauge
Picked both up from ECS and installed them.
With the stock DV when I let off the throttle I would get that cool flutter noise. I really liked it.
I installed the 008 and put the yellow spring in as I read the following.
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
I figured my 18PSI fell into the yellow category.
The valve does make a little noise but not nearly as much as the stock one did.
Boost and vacuum seem fine from the gauge. from 22 In-Hg to 18 PSI. (Around 15PSI on these 30'C+ days)
Should I switch to the green spring? Will this bring my noise back?
Thanks for the input.
