Results 1 to 11 of 11
    Mar 26 2012
    Brisbane, Australia
    A3 Weight changed from 2007 8p to 2009 8p?!
    I did some research and found out my car weighs almost 1.6 Tonnes!? ( or is this a mistake?)
    It is an 07 a3 Quattro 2.0T Manual.
    The 09 Models weight about 100kg less.
    Veteran Member Four Rings A3 Guy's Avatar
    Apr 01 2011
    Charleston SC
    I'm lost....there isn't going to be too too much of a difference, the 2.0 should be faster but not by a lot. Is one of them an S-tronic or are both manual. Not very clear as to what this post is trying to get at....
    ~Brennan
    2014 allroad Premium Plus
    Flickr
    Mar 26 2012
    Brisbane, Australia
    In the 2007 A3 2.0T Quattro it weighed : 1565 Kg - Manual
    In 2009 A3 2.0T Quattro it weighed : 1455 Kg. - S tronic
    what is the difference between the two models?
    Why is the older one about 100kg more?
    Jun 15 2009
    the added component for the quattro adds a bit of weight to your car, thus it negates your power advantage somewhat.
    Mar 26 2012
    Brisbane, Australia
    ... question is not being answered.
    Why is a 2009 Quattro A3 100kg less than a 2007 Quattro A3?
    what changed?
    Apr 01 2011
    Charleston SC
    I do believe the same happened between the MKV and MKVI GTI and I think all that's called is progress in materials and structural development.
    ~Brennan
    Flickr
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    Quote Originally Posted by A3 Guy View Post
    ^This. Just look at the MK2 TT vs. the MK1 TT Quattro or FWD. The weight savings in the MK2 is significant.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Jan 07 2012
    Jacksonville FL
    I concur, probably just lighter materials in an effort to increase fuel economy. I remember reading when the 2009 facelift came out that they also made some improvements to the undercarriage panels to increase aerodynamics (for the same reason.) In 2008, the EPA (in the US) changed their fuel economy rating system, which resulted in lower numbers for most cars, giving manufacturers even more incentive to find ways to up the economy. Yes, I realize you're not in the US, but these changes would be beneficial worldwide.
    I don't know if there is an appreciable weight difference between the FSI and TSI motors, but that was a big change between the two models too.
    One last factor to consider: we don't know what options the cars that were weighed were fitted with. Little things can add up, such as power vs manual seats, even cloth vs leather, 17" vs 18" wheels, etc.
    Mar 26 2012
    Brisbane, Australia
    I didn't think there was any significant changes with the facelift though..
    The mk5 to mk6 golf was an actual change with the chassis; and the entire look of the car.
    Here with the audi it still is the "8p" model; It seems like only a few headlights and tail lights got changed.
    Apr 01 2011
    Charleston SC
    Quote Originally Posted by khonfahm View Post
    The A3 had the same changes done just in a more subtle manner, in case you haven't figured this much out yet the MKVI and Facelifted A3 as well as the MKV and Pre-Facelift A3 are essentially the same with the A3 being simply a more refined and "mature" car and the GTI being its sportier more enthusiast oriented cousin if you will.
    It's still the 8p because that's essentially what it is but now it's just newer, lighter, more efficient and in turn it should be slightly more efficient.
    ~Brennan
    Flickr
    Established Member Two Rings Hatch-it's Avatar
    Jul 25 2012
    CA, U.S.
    Could the change to a chain driven camshafts have some effect on it? Maybe other parts of the engine were changed as well that could decrease weight...
    Also, what website is that image from?
