Results 1 to 9 of 9
    Jun 07 2010
    ny
    battery sparking, car clicks but will not start.
    So i just finished my turbo swap, got her back together, cranked her a couple times with no fuel pump fuse, last crank the battery terminal sparked, now if i try to start it, it sparks more and just clicks once.
    any ideas? i'm thinking maybe bad ground?
    just throwing this up to see if i get any ideas for when i start loooking at it in the AM,
    thanks
    Sep 18 2008
    lancaster,pa
    Check the main ground strap on the passenger side to the frame rail.
    Frankenturbos, Stage 3 tuning by Jfonz Tuning.
    Aug 13 2008
    Indiana
    Battery terminals were not tightened properly or were too dirty. Remove terminals, clean the connections, and reinstall with them properly secured and it should crank no problem. While just putting the terminal on the battery does transfer power, it is not enough to handle the high cranking amps you need for the starter and this causes the spark and the click no start.
    -Nic
    Established Member Two Rings waldnerstev's Avatar
    Feb 07 2012
    Juneau Alaska
    Quote Originally Posted by somebody5788 View Post
    ^^this, no question about it. seen it many times.^^
    Jun 07 2010
    ny
    so i tried it this morning, cleaned connections, now when i connect the battery, with no key in the car, stuff starts to turn on, headlights and something in the engine bay, the positive and negative wires get VERY hot, and start to smoke if left on, i do not have enough time to even try the key...
    is it a short? or did the starter go or??
    Jul 26 2009
    00 S4, 01 S4, 93 RX7 LS1/T56
    Dallas
    Sounds like you have some serious electrical issues. Are you sure that you didn't hook the battery cables up in reverse or do something else goofy by chance?
    Chris Sanders
    02 A4 Avant
    01 Noggy S4
    00 BB S4
    1993 RX7 w LS1/T56
    Jun 07 2010
    ny
    positive, the car was cranking just fine, then the battery sparked, and it would just click, now somehow overnight it doesnt do anything but burn the battery cables....maybe bad starter? pinched or shorted wire to starter? or bad connections on starter? the two grounds in the car are good.
    Jul 26 2009
    Dallas
    Well you definitely have a short to ground somewhere. That's why the battery cables are getting so hot. You'll want to disconnect everything and then start tracking down where the short is. Make sure you're really careful because you have the perfect recipe for a really bad fire or battery explosion right now. You might start with the starter wiring since it sounds like that was where the problem started.
    Chris Sanders
    02 A4 Avant
    01 Noggy S4
    00 BB S4
    1993 RX7 w LS1/T56
    Veteran Member Four Rings bigdo26's Avatar
    Jul 21 2009
    Hope you didn't fry the ECU
    2014 Mustang GT w/track pack and Recaros
    Sold: B5 S4
    Track videos: Watkins Glen
    Track videos: Limerock Park
