Results 1 to 15 of 15
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    Ground locations?
    Since i've gotten my motor back in i'm still working out little bugs..Problem i have now is my voltage is jumping, and i'm not sure if it's the alternator or just a loose ground. I'm leaning more towards a loose ground since i pulled the motor. Headlights are flickering etc, tho the battery is right at 12.5 volts every time i got to start the car so the battery is not draining. Now i'm just trying to figure out which one might be loose. Ground under the coolant tank is tight. I honestly can't remember what other grounds i would've disconnected? Any other ones i should check?
    Single Turbo Hibiscus coming soon
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    Thank you sir. ^
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    there is also a ground on the passenger side of the firewall. near the O2 sensor plugs.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    I only have the two mentioned. The main harness ground and I think 2 or 3 other wires go behind the coolant tank. 1 large ground goes to the post under the frame rail. Thats for a 2001.5, though. I dont have a ground on the passenger side from what I recall.
    WTB - Electric high flow fan kit - FORGE 007 DVs
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    Quote Originally Posted by MDJ View Post
    I don't have the one on the frame rail as i have a 2000. Ground under the coolant tank is all tightened up..Other than that i'm not sure where else to look? I really don't want to get a new alternator and have the same problem. Has anyone else had all kinds of shit fail after they pulled their motor lol? For fuck sake..First my power steering, then my clutch switch, now possibly my alternator. This thing certainly keeps you on your toes ..
    Senior Member Three Rings 155VERT83's Avatar
    Jun 30 2009
    ‘05 Porsche 997 Carrera, '15 MBZ C300 4Matic
    Alexandria, VA
    Quote Originally Posted by Dutchsider View Post
    Bumping old thread
    Does anyone have the torque specification for the frame rail ground connector?
    Sep 11 2009
    NE
    Quote Originally Posted by 155VERT83 View Post
    Bumping old thread
    "Gutentight!" . It is not load bearing so anything will do so long it doesn't undo itself. From the looks of it, 10lb/ft will be more than enough but I bet I put about 25-30 down when I tighten mine down... MEasure voltage drops with car running after you tighten all the electrical connections.
    Oh, and I am sure you know but... You're supposed to tighten it with counter acting two wrenches (base of post is keyed to 13mmm I think), not just by tightening the nut against body of car.... you don't want to rip the post out of frame!
    Jun 30 2009
    Alexandria, VA
    julex,
    Thanks.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Great info, I'm going to need this when I take my motor out. Thanks in advance.
    Aug 24 2014
    Newport Beach, CA
    Bumping this up, for an early 01 are the ground locations the same as what's highlighted above?
    2024 M3 Comp xDrive
    Jul 07 2009
    Alberta, Canada
    Mine is early 01 and the same as the above annotated pic
    Veteran Member Three Rings 1illA6's Avatar
    Aug 20 2012
    Arizona.
    I believe there's another wire coming out of the harness that connected to the intake manifold/EGTs as well.
    Nov 28 2020
    Ny
    Can anyone identify what this ground is for it's currently disconnected on my car and if you touch it while the vehicle is running it shocks the sh** out of you if I put it near anything it sounds like a razer do I have a short I've never encountered this with a ground. Should it go to engine or faux firewall. Thanks
    Quote Originally Posted by obijohn22 View Post
    Junior Member Two Rings NachO_GMC's Avatar
    Sep 09 2017
    W205 C63 Coupe, Maserati Levante Q4, Chevy Silverado 1500, 2004 SRT-4 (Race Car)
    KS
    Quote Originally Posted by keithoefelein View Post
    That sounds like a short. some troubleshooting with a meter is likely needed if you don't see evidence of damage/burnt ect ...
