Originally Posted by
Sole_
So just to update this. I took it to 3 shops to get re balanced. Each shop saw the wheel hop on the balancer. The last shop i took it to had the new Hunter Road Force Balancer. After an hour I was diagnosed with a bent rim. But not visible at all until the wheel is spinning on the balancer it was waving and hopping a tiny bit. It was recommended that rotating the tire about 80* degrees would help. Got that done and re balanced. I went on the hwy and still same shit. Awful vibration at 115kmh. Took the car home was sad. Left it there the whole day. I drove it today on the hwy about 30 minutes ago. Hit 115kmh there was no vibrations. ATM I am mind fucked cause I almost traded my LMs for Work Meisters plus cash on my end. I don't know what the delio is but I just drove it for 30 minutes at 115km/h and it was fine. So yeah I know this won't help but I thought I would update.
Did you get the print out from the Road Force Machine when the diagnosed the bent rim? What's the radial and laterial runout? The Hunter machine works great if the tech knows how to use it, I'd ask for the print out and verify.
What shop did you take it to?
