Results 1 to 36 of 36
    Feb 25 2011
    Seacoast NH
    Post Hardwire Escort Passport 8500 X50 Radar Detector
    DIY: Hardwire Escort Passport 8500 X50 Radar Detector in B7 A4
    Hey guys. I do realize this has been covered more than a few times, but the reason I am making this DIY is because I think some of the pics and video might help a few people down the road in their install. This install process can probably be used for other radar detectors as well, but obviously check on that before attempting anything.
    First off, thanks to those that helped me troubleshoot some of my issues. See this thread, and all of the linked threads within it for other ways and idea to do a similar install: http://www.audizine.com/forum/showth...need-fuse-help
    Tools and items needed:
    -Radar detector.
    -Radar detector smart cord with mute button.
    -Velcro (I recommend Velcro-brand squares that you can buy at most hardware stores).
    -Electrical tape.
    -Add-a-fuse (bought at a chain auto store; there are 2 different sizes of fuses in our cars - for my version of this install, I chose to go with the smaller fuse - so if you follow my DIY, you will want the smaller of the 2 add-a-fuses that will be available at your auto parts store).
    -Extra 10 Amp fuse (bought at auto parts store).
    -Insulated butt connectors (bought at Radio Shack)
    -Pliers.
    -Wire cutters/splicers.
    -Wrench - I used 5/16 wrench, but I believe there is technically a specific metric wrench that can be used as well.
    -Plastic zip ties.
    -Bone tool (bought at crafts store in the "paper-folding" or "scrap-booking" section).
    -Sand paper, or a wire brillo-style pad
    Difficulty:
    The most difficult part of this for me was trying to figure out what was a good fuse to "tap" into using my add-a-fuse. More on that later. I think this took me maybe 2 hours total. But I really took my time trying to not make any errors. If I were to do this again, it would maybe take me 1 hour or less. Not that hard assuming you have all of the tools needed.
    How-to guide with pics:
    The Escort brand smart cord (with mute button) costs approx $20, and is available from various stores online. Here is a pic of what were are talking about:
    Coming out of the mute button are two wires. Wire #1 is a phone-jack style wire, which will plug into the radar detector unit. Wire #2 actually will break off towards the end and become two wires. We will call these wires #2A and #2B.
    Wire 2A= The black wire that has a metal loop at the end of it. This is the ground wire. We leaving this wire as is.
    Wire 2B = The wire already came with a flat-style plug on the end of it.
    For wire 2B, cut off that flat metal plug on the end. Use wire strippers, and leave approx one inch of bare wire. Fold that wire over onto itself, so it is technically twice as thick as it was before. This folded-over bare wire will be crimped into the blue butt connector, and connected with the add-a-fuse.
    Depending on your add-a-fuse that you bought at the auto parts store, it may or may not already have a blue butt connector clamped onto it. If it is already there, great. If not, strip down some wire and with pliers crimp the blue butt connector over the bare wire. Now wire 2B should be connected securely with the add-a-fuse wire (red wire in pic).
    The ground wire (wire 2A) with the loop needs to be connected to bare metal. Take sand paper and scrape off the black paint. With wrench, remove bolt. Put bolt through the wire 2A loop, and secure with wrench.
    Take the add-a-fuse which is now secured to wire 2B with the blue butt connector. You need to be sure to have one extra 10A (10 Amp) fuse for this. I also bought these at an auto parts store. The add-a-fuse has 2 empty female slots ready for fuses to be added into it. Add the extra 10A fuse into the empty add-a-fuse.
    Now, for the next part there are apparently multiple fuses that can be used. The purpose of this is to tap into a fuse that will power on/off with the ignition of the car. This way you will not have to plug/unplug anything related to your radar detector when you enter/leave your car. I tried a few different ones without success.
    On the inside of our fuse panel, there is a nice detailed list of the fuses, and what "number position" they are on the grid of all of the fuses.
    The one that I used was fuse position #7. This is a 10A fuse. This corresponds with the ESP (Electronic Stability Program).
    ***TEST that your radar detector works here before messing with mounting or anything else. Make sure it powers on/off with the ignition of the car. If this is working fine, continue with install***
    I decided to mount my radar detector on the passenger side of the rearview mirror. This was a personal decision, mostly because I refused to lose the full motion of my driver's side sun visor. It will only partially block the passenger's visor abilities. It can still go down perpendicular to the ground, enough to block the sun if needed for the passenger. And the radar detector is still in sight for me, so I can see if it is K-band or KA-band, etc.
    Always start with the detector end, because this will allow you to have the slack at the end, and slack will go into the fuse box. Use the bone tool to help you route the phone cord flat under the headliner, and then down the A-pillar. I thought the rear-view mirror would be difficult and get in the way, but the headliner actually can bend upwards a bit, and you can route the wire over the mirror area. Continue with the bone tool. Make sure to give tuck it in really far into the top of the A-pillar, so it doesn't "pop" out and fall down. Tucking it down the side of the A-pilar was difficult for me. I used the side of the bone tool and patiently kept at this for probably 20 minutes. Be careful not to puncture the wire with your tool here. Then tuck this wire down and into the fuse box area.
    I used plastic zip ties to make it look clean. Use electrical tape around anything that might have the possibility of having a wire become exposed. That would lead to short circuits, etc.
    Now to discuss the mute button. I was aware of the "funk" button for Audi cars, but that is an expensive part, and the extra wiring/soldering seemed slightly above my expertise here. I used the mute button that came with my smart cord. I found a nice spot for it to the right of the steering wheel, and to the left of the radio console. I used Velcro with adhesive backing to secure the mute button to the side of the console. I like this spot because it is within an arm's reach, my passenger cannot see it, and people standing next to the car cannot easily see it (see: police). I routed the wires into the space where the two pieces of plastic come together. This bone tool really served its purpose, and I would not have been able to complete this particular install without it. I then used this tool to tuck the wire into a really tight crack underneath the steering wheel, and directly underneath the owner's manual storage compartment. The wires will then pop up from underneath and into the fuse box area.
    Make sure your radar detector is LEVEL to the ground. You do not want it tilted up or down too much at all. I had to mess with my suction cups for a few minutes until I was happy with this.
    Also, just for shits I made a quick video in case people want a quick version of what I did:
    Hope this helps a couple people. Feel free to post here for questions if needed, and I'll try to help. Cheers.
    Active Member One Ring PerkisizeMe's Avatar
    Jun 06 2012
    '08 B7 A4 2.0T Avant Titanium 6MT, '86 Porsche 944T
    Thanks for the DIY tutorial wildcat, this is awesome! I have been considering doing this for my V1 for sometime.
    B7 A4 Avant Titanium 6MT: EPL Custom Tune, Stratmosphere Hypershift Short Shifter, H&R Wheel Spacers, S4 Rear Valance (Unpainted), AWE Catback Exhaust w/Quad Black Tips, De-badged Rear A4/2.0T Emblems, H&R Rear Adjustable Sway Bar
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    looks good my 9500 is wired up the same way. But you should move in down an inch or 2 where you have it now the rear laser sensor is blocked.
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    Awesome DIY!!!
    couple things i will add:
    (1) if you get your own RJ11 cable, make sure that the wires inside are of high enough gauge each. otherwise you won't have enough voltage (happened to me)
    (2) if you take off your sunshade, the cable will slide in the corner and down the a-pillar with ease (and you don't have to worry about puncturing it)
    also i agree, if you place it below the mirror it will have much better visibility from the rear
    Feb 25 2011
    Seacoast NH
    Hey guys. Glad you liked the write up. I basically am conceding any rear laser detection with my setup like you said. I am fine with that. I still have rear radar detection though. Also, laser is very rare where I live. Plus, they say that laser detection is basically a "ticket identifier," anyways - because once you get hit with it, the police already have your speed.
    I do not want it too low on the windshield, because it becomes more obvious from the front that I have a detector - for police reasons; and for theft reasons. I certainly did not want it BELOW the mirror, or using one of those mirror mounts that are for sale, because that would block some of my field of vision of the road, which is not acceptable to me.
    Another reason that I like it where I have it, is that the top of the radar detector is physically touching my headliner, so this helps prevent it from bouncing when I go over bumps, etc.
    Good points you bring up though for anyone reading this to consider though!
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Thanks for the write up
    B8.5 Audi SQ5 | APR Stage 1
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    hmmm wildcat i may have to put mine up top and see how i like it, haha. for now it is basically right behind my mirror on the far side. i have a picture somewhere.
    as for laser detection, you're right... but at the same time i like to know so that i at least slow down haha
    i wanted to buy the hardwire kit but ended up getting my own cable because the hardwire kit doesn't come with a lead for the mute button. correct me if i'm wrong?
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by drumnjuny View Post
    I am not totally sure what you are asking. If I recall correctly, you did a custom mute button via a funk button in your dash; and if that is correct, then I'm really not sure how to answer your question. Basically, all of the wires I posted above with pics. From the mute button here, one telephone style cable comes out of it for what I called Wire #1. Then another wire comes out of that, which I called wire #2. Wire #2 then breaks off into 2 wires, wire 2A which is the ground wire, and wire 2B which is the wire that connects to the add-a-fuse that connects into the fuse box.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    my mistake. yes i didn't want to use their module which is why i wasn't able to use the hardwire kit. i do remember now my bad.
    Feb 25 2011
    Seacoast NH
    no worries dude. if I ever decide to do the funk button I'll hit you up for more info!
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    definitely! its actually very very simple. once my bigger car issues are taken care of i'm going to rewire it... when i do i can probably add a picture or two to this DIY for people who want to use the funk button.
    Feb 25 2011
    Seacoast NH
    ya! if you do re-wire it, try to make a totally new DIY with a million pics and diagrams, because eventually I want to do that, but I just couldn't justify spending $50 before shipping currently, and then trying to figure out how to solder wires and stuff.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    oh i didn't solder anything!! its actually a lot simpler than you'd think. but yes i will eventually make a DIY haha.
    Feb 25 2011
    Seacoast NH
    haha, goddamn funk button. ok lemme know.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    right but mine does not work too well right now haha. couple different issues, once i figure em out i will post a DIY
    Senior Member Three Rings igjoe1989's Avatar
    Jan 02 2011
    Beer Fridge
    Huntsville, AL
    "Better to be a warrior in a garden, than a gardener in a war."--Bruce Lee
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    most of those pictures don't work anymore for some reason? lame... but yeah that thread has some info in it that might help.
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    followed this write up and just did mine, worked great! I do have one question though, I am having issues with getting the velcro to stick to the interior. Did you use the one that came with the kit or something else? I went and picked up black command strips thinking they would stick better but am still having issues. It may just be how cold it is here, but if you did use the original velcro do you have any other suggestions?
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by Der König View Post
    Glad it mostly worked for you!
    I installed mine in July, so I am almost positive that is why you are having issues with the Velcro and cold interior plastics. I did *NOT* use the velcro that came with the kit (mute button and wires). I went to Home Depot and got some nice and thick Velcro-brand squares. I then cut it to fit the weird shape of the mute button, and stuck the sharp (hooks) side onto the mute button, and put the soft (loop) side onto the car with the adhesive backing removed. Try to get some of that product, and even if it is not warm outside, I would put a hair-dryer to the interior dash plastic (carefully) to get it up to 70-80 degrees or what a nice summer day would feel like. That should help with the adhesion. I also pushed the mute button with it stuck onto the interior trim piece for the first time VERY hard and held it there for probably 1-2 minutes to try to get a good adhesion.
    Also, since I posted this DIY, I have flipped over my mute button, and now have the actual button on the bottom of the mute button piece (versus the top like in my pic above). I found it easier for my hand to blindly find and push it in. Just something to think about if you have to re-do this again anyway. And I just used some Goo-Gone adhesive remover to undo the Velcro piece off the mute button.
    Hope this helps. Reply back if you have any other questions.
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    best mod i have in my car, lol!!!
    i opted out of using their controls, instead used the funk button. totally worth it IMO
    Feb 25 2011
    Seacoast NH
    I remember you had issues with the phone cord at first. Can you post what spec or gauge or wire you used? Did you use a DIY to wire the funk button? Like what like go where and stuff.
    Apr 15 2007
    WNC
    Ordered a 9500ix and hopefully the right stuff to do this. Hope its not hard! Would love to have radar on all the time in a non-obvious place.
    2013 RS5, 2014 Q7
    Feb 25 2011
    Seacoast NH
    Ya it's not too difficult. Post questions here and I can help if you have questions.
    Apr 15 2007
    WNC
    Hrm. So I did the install basically as above minus stripping paint off the ground because I wanted to see if it would work and it was fine yesterday. But today I got a low voltage prompt? I havent opened up my fuse box to see if something moved btu thought that was odd. Anyone have that happen before?
    2013 RS5, 2014 Q7
    Feb 25 2011
    Seacoast NH
    Hmm. Not sure honestly. Try to scrape that paint off like I did. It's hidden so didn't bother me that it wasn't clean looking. Let us know if that helps.
    Apr 15 2007
    WNC
    Anyone else? Yeah I'll see what happens.
    2013 RS5, 2014 Q7
    Apr 15 2007
    WNC
    God damnit. I had sent in my v1 to get updated so I received it back and it came with a different hardwire kit. Went ahead and tried to use that kit and use the same ESP fuse and no luck. And of course, now I have a new problem. I put the fuse back in just as it was before and now the car's ESP light wont turn off. FML. I reseated the damn fuse a few times and no luck. Any Ideas?
    2013 RS5, 2014 Q7
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by rnp614 View Post
    I would get a fuse tester to make sure that the ESP fuse itself didn't blow somehow. I have something like this: http://www.amazon.com/Bussmann-BP-FT...ds=fuse+tester
    If the ESP fuse is blown, replace it. If not, it's difficult for me to say because you're using a different hardwire kit and different detector than my Passport. You could also try to post in the gps/radar threads from the main forum page if no one else here chimes in.
    Oct 04 2011
    Rochester, NY
    I am having a similar issue with my hardwire. When placing the add-a-fuse in the ESP location, my ABS light comes on and brake light flashes. I replaced the fuse, checked again and everything is ok. So I tried the #5 location (something with maintenance light) and my oil pressure light comes on. replaced fuse, everything back to normal.
    I tried using the tire pressure light location, but no go.
    Not sure what is going on. At this rate I might just use the type of tube fuse that comes with the Escort Smart Cord and tap into a switched power supply.
    Apr 15 2007
    WNC
    Yeah I'm going to just have my garage figure something out and have them tap something. I dont have the escort thing, I have Valentine stuff but i'm sure they'll figure something out. Too bad the add a fuse shiz doesnt work for us.
    Out of curiosity what year is your car? Mine is a 2007.
    2013 RS5, 2014 Q7
    Oct 04 2011
    Rochester, NY
    I have an 06. I am doing custom wiring, not using the escort cable, because Im hooking up the Funk button.
    Everything works, just not that add-a-fuse. button works fine, even lights up.
    Just need to figure out another switched power supply and tap into headlight switch to control button lighting
    Oct 04 2011
    Rochester, NY
    well I figured out why the add-a-fuse wouldn't work... it has 2 spots for fuses. A spot for each circuit. I only had 1 fuse in there, so the radar would work but the ESP circuit would be open. Put in 2 fuses, and works like a charm.
    Now just to figure out how to take the pins out of the headlight switch connector, want to solder a wire right to the pin of the wire, so the button is lit at night
    Apr 15 2007
    WNC
    Odd. I put in 2 fuses and it still doesnt work for my Valentine....wtf. You put in 2 10 amp fuses?
    2013 RS5, 2014 Q7
    Oct 04 2011
    Rochester, NY
    yes 2 10amp fuses. Have you tried flipping it around? the back of the package said something about swapping polarity...
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0, Q5 B8 3.2
    Awesome. I've been siting on my smartwire for years. New project this weekend. Cheers!
    Feb 25 2011
    Seacoast NH
    Quote Originally Posted by nananana4k View Post
    Nice!
