Results 1 to 6 of 6
    Dec 28 2011
    Koebenhavn
    Sleeper Audi A6 Avant 2.7T 2001 - Stage 3 build
    So this is my stage 3 build, which is actually almost over.
    A little info about the car:
    Audi A6 Avant 2.7T manual 6 speed from 2001 with around 130.000 km.
    I imported the car from Germany in the end of 2011 and then I had it stored to the start of 2012. Had to sell my Audi S2 Coupe and my Suzuki Swift first.
    Here is just a couple of shots of my old S2 Coupe, sometimes I do miss it.
    Car was chipped by MTM, which turned out to be a bit of pita. More about that later.
    Car has the following equipment:
    Full sport interior with electrical seats.
    Dual zone climate control
    Heated seats
    Xenon lights
    Telematics system which did not work anymore - So I bought a stock Audi Bluetooth module and fitted that instead of the Telematik unit. Works like a charm.
    Walnut tree interior.
    Audi Sound system, but I changed that for a BOSE sound system instead. Was a bit of a pita to change the wiring, but it worked out great in the end :)
    I'm missing the cruise control but I bought one from Kufatec. That will be installed very soon, pictures to come.
    Multi function leather steering wheel.
    Symphony II radio - I'm considering getting a RNS-E navi system since the car already has GPS etc. from the Telematik unit. But currently my good old Garmin will have to do.
    My stage 3 builds is actually almost complete, just need to change the fuel pump and get the mapping done.
    Here is a bit of info, will try and take some more pictures of the parts and the car.
    Wagner Exhaust manifolds
    Wagner Intercoolers - Only had to trim the carbon air intake ducts a bit and everything else was a perfect fit.
    Wagner 3" SS downpipes with sports cats - I had to cut and weld the right downpipe so it would clear the gearbox bracket, but besides that it fitted perfect.
    The rest of the exhaust was changed with a Jetex Exhaust system in 2.5". Only adjustment to this was that I had to add reduction so it would fit over the downpipes and adjust the total length. (Pictures to come).
    KO4 turbo's - Here is a couple of pictures when had to pull the engine.
    All the small bits and bobs
    034MS 89mm MAF housing with OEM RS4 hose - Drilled a small hole in the RS4 hose and stuck a rubber gasket in it to accommodate the stock PCV hose.
    DW300 fuel pump - Still needs to be installed, more pictures to come.
    Bosch EV 550cc injectors - With stock o-rings at the bottom and S2 injector clips. The S2 injector clips makes it easier to turn the injectors a bit so there is room for the electrical adaptors.
    Forge Motorsport silicone hose
    034MS throttle body hose - The forge wont fit under the stock cover.
    RS4 intakes pipes
    RS4 Clutch
    Brand new stock items: N75, MAF, DV's, EGT's,
    I'm converting to 2.0 TFSI coils, more about that when I get it done.
    Regarding the MTM chip then it turned out that it had a crypto socket.
    Since my plan was to use Nefmoto flasher to change the software I had to do something. I found these nice things form a shop in germany www.chip-service.de
    Then I just had to solder the new chip onto the small board and flash it with my Galletto cable and then everything was good again. But bloddy annoying with the MTM crypto socket.
    A bit of info about the suspension and brake setup:
    I'm running stock dampers with H&R 40/40 lowering springs.
    Regarding the brakes this is pretty stock at the moment, running Zimmerman 312x30 discs with stocks pads. Boring
    Any suggestions to a front brake upgrade that will look like stock but give me better stopping power?
    Also a 200km/h when going to freeway curves the car feels a bit sluggish. Is there any whiteline ARB or similar for the A6 to stiffen it up a bit?
    Well here is a couple of pictures of the car with the old summer rims from MTM. However I ended up chaning them to a set of OEM Audi S6 C5 wheels so it would look a bit more like a sleeper.
    Jan 10 2010
    B6 Passat
    Nassau County
    looking real good
    Drive low, park lower
    Veteran Member Four Rings NickyAsixx3sixx's Avatar
    Oct 16 2011
    Levittown, NY
    Wow. Awesome!!
    2001 A6 2.7T - EPL TUNED, Bright Blue Metallic Vinyl Wrapped, ST coilovers, Miro 111s 19x9.5s all around on 225 tires, 3" SRM downpipes, AEM Meth kit, Magnaflow mufflers, JHM LWFW, JHM Stage3 clutch, B7 RS4 PP, SRM bipipes, JHM Solid linkage
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    Well, you got the sleeper part right.
    Why KO4s? Steered away from FT and TiAL?
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Dec 28 2011
    Koebenhavn
    Quote Originally Posted by Brens View Post
    Well I did look at other solutions, but since I was offered a set of new K04's for a very good price I ended up with that.
    Veteran Member Three Rings JakAzz425's Avatar
    Aug 14 2011
    2000 Corvette Convertible, 2002 Corvette FRC, 2018 Honda Odyssey
    Tulsa
    Drool......
