Results 1 to 40 of 40
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Thumbs up Meanwhile... my South Bend clutch experience
    So as some of you might know before my S4 was taken for me my South Bend clutch started to slip, after being certain that it is indeed the clutch I contacted South Bend via email.
    Andy @ South Bend replied to me and asked a few key questions (what exact clutch kit, what FW, etc, etc) and went on to recommending that I re-break in the clutch as it's been seen before that the Feramic can glaze over.
    Keep in mind that I bought this clutch kit from Avalon quite some time ago through one of their specials and didn't install it until I put in my 605's. I ordered their Stage 4 (at the time) which was the hybrid full face Organic/Feramic disc with the HD PP which I then mated to the TTV single mass steel flywheel.
    And while the clutch didn't see more then 9k miles, it did get to see quite a bit if hard driving, launches and track time... All that abuse and it was still easier to drive then the old OEM clutch that was in the car, I was amazed.
    So, I re-broke in the clutch but same thing happened it would slip every time I would get into boost from 3rd gear (from boost on-set), I then tried dialing down the boost ramp and the clutch no longer slipped. So it was obvious to me the clutch had to come out and that it just could no longer hold the power. I didn't understand why or what could have caused it to fail so soon but that was the case.
    Either way, once I had a chance to pull the clutch kit from the car (after it was recovered by the Police, etc) it became clear that it was no normal failure. Both materials had lots of life left the PP looked good as the flywheel. Then I noticed the clutch disc itself had crack leading from every spring causing the disc to flex.
    I emailed the pics to Andy and he said that is an older disc design and that they no longer use it because of similar failures.
    That said, I sent the whole kit and FW back to SB to have the disc replaced and the rest of the kit checked and machined back to new. I can honestly say that at this point there is no other Clutch manufacturer that I would give my money to before South Bend. Even before this I was recommending SB to my friends looking for a good solution for their cars (some did end up buying a SB) and now of course I am even more inclined to do so again for my new project and anyone else that happens to ask me for my opinion.
    After some of the negative threads recently about Clutches and such I thought it would be good to share my story and know now why I made the right choice going with SB, and believe me it was a lot of reading and research before I came to terms with my choice as many of you know there are a lot of options out there and the S4 is not nice to clutches when driven hard.
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    Thats some great customer service.
    Oct 27 2011
    TOYS
    Philly Suburbs
    My friend has a similar story, apparently he bought a used stage 3 endurance clutch to go with his fts. Well when he received the used clutch it turned out the rivets on the clutch were loose. He did some research and discovered southbend got in a bad batch of parts which lead to several kits with this failure mode. My friends calls southbend and they end up rebuilding his clutch and resurfacing his dmfw for free. Talk about amazing customer service!
    Aug 13 2008
    Indiana
    I had a South Bend in my A4 and that thing took crazy amounts of abuse even for just being a 2.8. If I manage to go FT I will probably be going with another SB clutch (assuming my RS4 clutch doesn't hold) It also helps that they are ~30 miles from me and I can actually go in and pick up the clutch as well as get wholesale price (parts manager at the shop I work for)
    -Nic
    Established Member Two Rings sean01S4's Avatar
    Oct 27 2008
    2001 audi s4
    Andy is the man!!! He did the same for me also...I had a problem with my clutch sticking and he had me ship it out and he rebuilt everything and shipped back free of charge!!! Some great customer service if you ask me.....southbend ftw!
    | EPL | 034 | Precision | Aquamist | H & R | Bilstien | Awe | Jhm | Apikol | Bosch |
    Tell me why your mad........
    Oct 29 2005
    10speed
    San Francisco, CA
    SB all the way. Clutchmasters has so many failures and bad QC. I got my entire setup from SB rebuilt twice (not because it was bad, I just had the motor out) for like $230 each time, literally brand new again. Can't beat that. Held up to 460+awhp and over 50 7k+ clutch dumps, rolling all 4 tires.
    - Clint
    Sep 17 2005
    Fremont, California
    Andy is a great guy to deal with, and that's great to see how quickly they addressed it, Notorious.
    Every company is bound to have clutch issues at some point, especially on an item that can be so touchy with installation and break in, but it makes all the difference when the company backs up their product.
    I'm currently breaking in my Southbend Stage 4 Extreme 6 puck on my single turbo. Once they are broken in, they really do drive almost like stock, with just a bit stiffer pedal that gives better confidence. KEN@034 is loving his Stage 4 Extreme 6 puck on his Tial 770R car. Handles the 550 ft/lbs no problem, and a chick could drive it in traffic.
    Just don't get discouraged by the break-in; they feel terrible at first hahahaha.
    Senior Member Two Rings str8blst's Avatar
    Mar 23 2006
    15 McLaren 650S, 13 GTR BE, 11 Q7 S-line, 11 Cayenne Turbo, 07 RS4 APR 1740, 91 GMC Syclone
    I had great experiences with SB as well. I went through two different clutches before they foud one that would hold. I believe some of the work a development that went into the clutch in my car is now being used on their production pieces. I had dinner with the SB crew a year or so ago at WF and they were a great bunch of guys. Knowledgeable and seemed to love cars just as much as we all do. For my S4 there is only one clutch I would use... SB....
    Jan 29 2009
    That's awesome, I'm glad to hear that many people have had just a good of an experience as I have!
    Max, yes a clutch will never show it's true colors until it's fully broken in :)
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    I'm not sure why I ever even considered another clutch manufacturer, especially after having one in my MKII GTi. I just got my DXD-HD series from them a week ago. Andy and his son were absolutely a pleasure to work with and I have no doubt that I will use them from here on out.
    Veteran Member Four Rings witwer4444's Avatar
    Dec 13 2008
    Palm Beach FL
    Just out of curiosity (and after a quick google search), who are you guys purchasing your S4 SB clutches through?
    Current:
    2005 Black W211 E55 AMG
    Sold:
    2002 Stering Grey E39 M5
    2001 Nogaro Blue S4
    May 13 2011
    2015 BMW F30
    Only clutches I would consider are Southbend and Clutchmasters.
    | Autospeed | JHM | Pure MS
    Jun 29 2010
    Quote Originally Posted by witwer4444 View Post
    Just a personal view on things, but I prefer to deal directly with manufacturers as often as possible. Don't get me wrong, there are plenty of stand up suppliers out there and those that regularly contribute to these threads really make things simple when there are questions or issues with products. Not to mention they usually have close working relationships/friendships with a lot of suppliers.
    That said, I would opt for dealing directly with South Bend first. Second, obviously 034.
    May 16 2008
    South Texas
    I offer Southbend products, and often can make a better deal on clutches than Southbend themselves.
    Southbend had been very liberal with their warranties. They have taken care of a few of my customers that had a catastrophic clutch failure 2+ years after the warranty expired.
    Jun 29 2010
    +1 for Scotty, too.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by MDJ View Post
    Thanks for the reference.
    We are a long time South Bend dealer, but I am pushing them more and more now that a lot of us are running them here @ the shop.
    If anyone is looking for a new setup, feel free to PM me for an Audizine price. Combine it with some other parts, help out even more!
    Sep 14 2009
    s.e. mass
    Quote Originally Posted by Max@034 View Post
    so, whats your shop experiences with the Spec 3+ versus these Southbends... Im just curious as you guys repped the 3+ for a while.
    IG: @PB5S4
    Jan 25 2006
    A4 2.0T
    MD
    I have been running my SB stage 3 drag clutch on my FT setup since Jan '11. A couple trips to the strip and it hasn't skipped a beat. I am very pleased.
    May 13 2011
    2015 BMW F30
    Max, why the move from Spec to SB? Did you guys stop selling them as well?
    Sep 17 2005
    Fremont, California
    I have run both SB stage 3 as well as now stage 4 extreme and have loved both. The stage 4 took a good 800-1000 miles of break in but is well worth it. I was surprised how great it feels and holds my power with no problem. Feel free to contact Max or myself for any clutch inquires.
    Veteran Member Four Rings topquarkpc's Avatar
    Aug 03 2009
    PNW
    just wondering how this can heppen...
    Quote Originally Posted by NOTORIOUS VR View Post
    '01 Imola Yellow Avant Sport Package 6-Speed (stage 3 w/Frankenturbo F4H)
    Sep 17 2005
    Fremont, California
    the sprung disc wasn't designed for the hard driving this was probably put through.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    MUST BE NICE
    hahah..... nice work soutbend
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by S4 00 2.7 View Post
    Pretty sure they sell both southbend and spec as well as clutchmasters and some others
    Feb 28 2007
    chicagoland
    I hope they did
    Nogaro 01 s4
    620whp 93octane
    Sep 17 2005
    Fremont, California
    We sell Tilton, SPEC, Southbend, and Clutchmaster. Not to mention factory replacements. Basically any clutch you could need or want.
    Sep 17 2005
    Fremont, California
    To be extra clear, KEN and myself are using a Southbend Stage 4 Extreme 6 puck Graphite Impregnated Sprung Hub... there are various options for disc compound, full face, etc. They will drive differently and change torque capacity.
    Quote Originally Posted by naudlee View Post
    We most definitely have not stopped selling SPEC; we will continue to sell them for years to come, as they are the company we have the best overall experience with. We've sold countless numbers of them, and the failure rates are lower then any other clutch company we have dealt with. We've been selling SPEC 3+ clutches for years and years, and it has been the preferred single disc clutch for B5 S4s. We've taken the smaller Coupe Quattro SPEC 3+ w/ Superclamp to over 800whp on our VR6-T B5 A4.
    My reasoning for now pushing the Southbend clutch over the SPEC clutch is more that I like to rep products that I use myself and have experience with.
    Both KEN and myself (and 034) wanted to see what this Southbend Stage 4 Extreme could do for us and for future customers so we both decided to be guinea pigs. We've been seeing more forum members going with this clutch, and I have friends who use it, so we were curious for ourselves. We like testing everything before pushing it. While the 3+ has been a great choice over the years, we wanted to confidently offer another option that can handle big turbo B5 S4 power.
    The results have been stellar and we like dealing with Southbend, so KEN and myself are now pushing this setup over the traditional 3+. The fact that it comes with a great steel flywheel is a big plus as well, as the driveability is even nicer with the heavier weight (but it won't rev as quick).
    Every clutch company is going to have some issues at some point, so it is always interesting to see what people deal with; clutches see the most abuse out of any component on a vehicle, especially a high powered vehicle. There are bound to be mistakes made, and you'll see complaints about every clutch company out there. Southbend tends to be a bit more forgiving with replacements, so they tend to get a good reputation from this aspect.
    Quote Originally Posted by KEN@034 View Post
    Yep! We have Clutchmasters TD850's (aka FX850), Tilton triple disc carbon clutches, B5 RS4 hybrid clutches, stock OEM replacements...and everything in between.
    Jun 29 2010
    Sick spot in European Car, Ken. I effing LOVE those wheels. Gorgeous. Too bad they are more than my 605s!
    Mar 01 2012
    Brentwood ca
    hey max can you hook me up with a southbend stage 2 endurance and your shops light weight aluminum flywheel? I'd like to get one asap
    May 16 2008
    WA
    Quote Originally Posted by sheeyees4 View Post
    this thread is almost a year old
    you are better off PM'ing him, although I am not sure if Max is back at work from is vacation or not.
    May 13 2011
    2015 BMW F30
    Contact Laszlo@034
    X2 I think Max is still getting in trouble in Europe.
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    South bend is great
    Amazing customer service, thet take care of their customers and stand benind their product.
    2000 S4 - silver- RS4 OEM widebody racecar
    Aug 03 2009
    PNW
    Not sure about SB but I sure got the shaft when I called up CM...
    Not gonna be returning customer for sure...
    Jan 24 2010
    Paramus,NJ USA
    I posted a SB clutch story in a b6 a4 forum.Also nothing but a great experience and outstanding customer service.I only recommend SB clutch kits to my clientele.
    Ziddy Autowerks
    Veteran Member Three Rings greg@dubaudi's Avatar
    Feb 05 2005
    2001.5 pearl WB Avant, 2016 SQ5
    Alton Bay, NH
    Big for south bend one of the best clutches I have owned. I had a stage 3 endurance and now run the stage 4 extreme. Both are awesome for real world driving of the car.... I buy from Scotty and he was great to deal with and answered all my questions.
    If anyone is looking for a great deal on a lightly used SB stage 3 endurance with SB SM flywheel send me a email [email protected]
    2001.5 EPL/Tial 770 Pearl WB Avant///2021 SQ7 Nimbus Grey///2021 GMC 3500 Duramax
    Aug 24 2014
    Newport Beach, CA
    For you guys who run the stage 4 clutch, how did you go about breaking it in properly? Installing it with Clutch Master's steel flywheel with my build.
    2024 M3 Comp xDrive
    Oct 27 2011
    TOYS
    Philly Suburbs
    500 miles of city driving with lots of shifting and first gear starts. No wot/boost until then.
    Aug 24 2014
    Newport Beach, CA
    I'll have to just do one long ass break in drive then, thanks Monty.
    2024 M3 Comp xDrive
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by christianb5s4 View Post
    took me about 2 weeks with normal trips/daily driving.
    Aug 24 2014
    Newport Beach, CA
    Unfortunately my commute is 9 miles round trip to my office, albeit in some traffic. So it would take forever to do the break in period just by commuting. I'm super excited though, goal is to have everything broken in by Wuste.
    2024 M3 Comp xDrive
