Recently purchased a VAG-COM which yielded some interesting results about my (mystery 3- tune)
Here are some OVER simplified numbers:
ECU Requested ACTUAL
Boost 18.5psi 14.8psi
MAF Spike: 252 g/s (95 degrees outside)
but here is the one I am quiet confused about:
From 3500-6750 my A/F ratio recorded by the VAG-COM hovers around 19:1 (FULL THROTTLE) ....which is incredibly lean.
I mentioned in previous posts on this forum I thought I had a Full 3- tune but was confused with the 4bar FPR.. could this be causing this lean A/F ratio?
Would a simple change to a 5bar FPR correct this problem? I believe but am not sure.. that if this car had a full 3- tune using a correct 5bar FPR and it was replaced by a 4bar FPR at some point it would make the engine run lean.. like I am observing.. is this correct? I have a new one from Neuspeed and that I will install soon, unless this might not be the solution. Otherwise perhaps the Fuel Filter could be the culprit. Either way I know the car should not be running this lean. I have seen posts about 12:1 being ideal for a Stage 3 or 3- tune. The 19:1 is bad for the engine and is obviously robbing me of power and causing my turbo's to under boost.
Anyone have this RUNNING LEAN issue with Stage 3 or 3- tunes?
Any thoughts?
Thank You
