Results 1 to 16 of 16
    Senior Member Three Rings titanium3.2's Avatar
    Dec 17 2007
    Springfield
    Quattro explained
    there are alot of very knowledgeable individuals in this model forum so I wanted to also ask this question here too.
    http://www.audizine.com/forum/showth...40#post7737640
    TIA
    Veteran Member Three Rings Adub-Drew's Avatar
    Feb 07 2010
    Wilton, CT
    Okay I'm no expert on the topic but i do know a little bit. Here's the breakdown Quattro has two different Quattro setups. One is called Haldex, and another is Torsen. Torsen is the one we have in b7's and is a mechanical system, it always works and has power being fed to all four wheels at any given time. However it can send more power to any which wheel with the aid of electronics i believe. Haldex found on the TT, a3, and any other Audi that has a motor latitudally (not sure if thats a word, or what to call it) mounted, More or less the same way a fwd car's motor generally is. It permanently sends power to the front wheels and there is a viscous coupling that engages the rear wheels when it senses that the two front wheels are spinning at different speeds via electronics. However after some wear of engaging and disengaging it starts to fail. This is why haldex is a inferior system, and in my opinion should not hold the same "quattro" badge.
    Haldex Explained, nevermind the whole saab thing.. More or less the same stuff..
    Here's an example of quattro..
    B7 A4 tip (daily) Mk6 Gti Drivers Edition (toy) Soon to come Mk4 R32
    Dec 17 2007
    Springfield
    ^ that was informative. If I was understanding the English properly then the system uses the brakes while cornering to change the crown gear distribution? Not the greatest design I would think.
    According to some quick searching the torsen in our cars I bolted to the end of the gear box. Then the question is how does the power get to the front wheels? A propshaft inside the transmission housing ?
    Established Member Two Rings Tcass's Avatar
    Oct 10 2010
    2006 audi a4
    Bensalem PA
    Awesome videos bro! I love my Quattro!!!
    19" Volk CE28N | STaSIS/Alcon 355mm Mono4 BBK | Koni Coils | AWE Exhaust | RAI Test pipe | 30% tints | GIAC 93
    Veteran Member Four Rings JPT's Avatar
    Oct 11 2010
    '05 Kawasaki Ninja ZX12R
    Long Island/NY
    Quote Originally Posted by titanium3.2 View Post
    It is actually a good design to use brakes. You have a couple of options (like any differential) clutches (wear out over time), gear driven (also a good design), or brakes. Gear driven, is great for off roading, and has proven to be strong and last a long time (based on the strength of materials). Using the brakes, is not ideal if YOU are the one applying the brakes, but with highly advanced traction control systems, they can control front to back and side to side. We only have pedals that apply brakes evenly to all 4 wheels, but the computer in a traction control system, can apply brake force to each wheel individually as needed, many times per second. Allowing power to be diverted to one wheel.
    Feb 07 2010
    Wilton, CT
    Quote Originally Posted by Tcass View Post
    Thanks, i love quattro. My dad has a 328xi and although its awd system is sadly faster to react than quattro to shifting power to the right wheel. The bmw solely relies on electronics, whereas the quattro is more mechanical and will work non-stop at the end of the day. Quattro is a great awd system.
    Senior Member Two Rings alpinevr's Avatar
    Feb 28 2009
    Spokane, wa
    The nice thing about the haldex system is you can get a controller to alter the characteristics.
    http://www.hpamotorsport.com/haldex.htm
    Jun 27 2011
    Also it's transverse mounted not latitudinally. Haha.
    The Torsten system the longitudinal audis use is the most durable system out there. The electronic systems' achilles heel is that it relies on electronics to work whereas torsen systems work through pure mechanical physics. You might think it's a weak point but the brakes are generally on of the most dependable systems on our cars. Therefore having them in charge of distributing torque in adverse conditions is much preferable to a computer controlled diff.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 07 2010
    Wilton, CT
    Transverse, thats the word I was looking for haha..
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by alpinevr View Post
    That’s pretty cool
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Three Rings Acme's Avatar
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    BTW, the system in our B7 isn't the last generation with the crown gear... The ratio is 50:50 and EDL is used to control wheel spin on one axle, using ABS sensors and brakes.
    The last iteration with 60:40 ratio was introduced in the B7 RS4 and is used in the B8. The crown gear was introduced later I think...
    2013 Daytona Gray A4 Premium S-Line Quattro 6MT - NAV - bi-xenon - adaptive dampers - Alcantara - Eron's rear view cam
    SOLD! 2008 A4 2.0T Quattro 6MT Unitronic stage 2
    Feb 07 2010
    Wilton, CT
    Quote Originally Posted by Acme View Post
    That's correct, we only have a 50:50 spilt! But that is better for when we have bad weather!
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by Adub-Drew View Post
    It's a 50:50 default split but can apply up to 75% of torque transfer to either front or rear axle.
    Quote Originally Posted by Wiki article
    quattro generation IV
    [citation needed]
    Starting from 1995 on Audi A4/S4/RS4 (B5 platform), Audi A6/S6/allroad/RS6, Audi A8/S8 with both manual and automatic transmissions. Also on VW Passat B5, where it was initially referred to as syncro, but by the time it reached US soil, it had been re-christened 4motion. Also used on the Volkswagen Phaeton and Volkswagen Group D platform sister vehicles. The Volkswagen Touareg used 4Xmotion with a separate transmission, PTUs and front axles.
    The manually locking rear differential from the earlier generations was replaced with a conventional open differential, with Electronic Differential Lock (EDL) (which detects wheelspin via ABS road wheel speed sensors, and applies brakes to one spinning wheel, thus transferring torque via open differential to the opposite wheel which has more traction). EDL works at speeds up to 80 km/h (50 mph) on all quattro models (on non-quattro models: up to 40 km/h (25 mph).
    System type: Permanent four-wheel drive.
    Torsen type 1 or 2 centre differential, 50:50 'default' split, automatically apportioning up to 75% of torque transfer to either front or rear axle.
    Open rear differential, Electronic Differential Lock (EDL).[4]
    Open front differential, Electronic Differential Lock (EDL).[4]
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Mar 28 2012
    Aprilia Tuono V4
    Québec
    And you should have a look at the Haldex system in the Golf R. I used to think that a Torsen system was better, but I'm not so sure anymore...
    Veteran Member Three Rings funky_snowman's Avatar
    Dec 31 2010
    US
    torsen used to be considerably better. personally, i think it still is. however, haldex has come a long way. the newer versions can actually transfer more power to the rear than 50%, which is a huge deal for haldex imo.
    a lot of people see "electronics" as being a bad word, and there certainly are benefits to mechanical systems. However, when you look at cars like the EVO X and GTR, it's pretty clear that you can do some cool stuff with electronics that just aren't possible without them.
    Veteran Member Four Rings Salt n Peppa's Avatar
    Apr 04 2012
    Schwinn
    Minneapolis, MN
    Interesting thread! Way to break it all down.
