Results 1 to 17 of 17
    Veteran Member Three Rings A4pilot's Avatar
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Steering rack replacement cost? Is it worth it?
    My a4 just made it past the 200k miles mark and today my steering rack went. Fluid pouring out of the bottom of the car...nursed it home, etc. I'm wondering how much the job would be for a new rack, parts&labor and if you guys think it is worth doing on such a high miles car. Opinions please....thanks!
    Senior Member Two Rings lorge1989's Avatar
    Jan 27 2012
    Buffalo
    How do you know its the rack. Could be a simple as a sliced line.
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Not sure, how would I check if it was a line?
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    I know that the fluid pours out when I turn the steering wheel to the full right position. I'm not sure if that could still be just a broken line or rack replacement?? When the wheel is full right the fluid drips from the drivers side area on the ground....
    Jun 30 2008
    Erie, Pennsylvania
    I think the last rack replacement we did on a B5 Passat 2.8 was $700 installed or so. It's kind of a pain to do. It is a bit easier on a 1.8T because the 2.8 driver side exhaust is not blocking access to one of the rack bolts. Even easier if it's manual trans.
    Mar 18 2008
    I remember i got mine done two years ago for around $1000 canadian.
    APR chip, APR turbo inlet hose, evolution fmic, h&r coilovers, ddm hid, S4 projectors, forge dv, vdo boost gauge.
    Jun 24 2012
    2001 SLK230 Kompressor
    Silverdale, Wa
    I have never seen a dead rack.. ever.. It has always been a feed high pressure line. If so, the lines are ~$200. If you send it to the stealership, god knows how much it will cost..
    clean up the mess, get under the car (stands or a lift) and have a "friend" spin the wheel and see where it shoots you in the face from. Thats step #1
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Thanks, I will take a closer look at it today
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Anyone know a place that sells steering racks cheap? It's confirmed, rack needs to be replaced &$!?$&'b
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by A4pilot View Post
    look on the bright side - at least you'll never have to do it again, LOL
    http://www.mjmautohaus.com/catalog/p...oducts_id=1009
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Nov 07 2010
    South of Heaven
    Quote Originally Posted by BlazinB5 View Post
    How is that, does this have a lifetime warranty on the rack? This is a rebuilt rack so it has already failed at least once so I wouldn't hold my breath on the lifetime thing. And these racks do fail, mine is on the way out and the guy I buy parts from says he sells enough of these so they are not all that reliable.
    - 2000 Audi A4 QTM
    - 1994 Corrado VR6
    - 1991 Jetta G60 Coupe Syncro
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Thanks, but this will be my second time replacing it.....
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by Corrado_Guy View Post
    i've never had a power steering rack fail so i wouldn't really know. i just know where to get the parts.
    it looks like ECSTUNING wants another $200 for the same part/brand ($846!):
    http://www.ecstuning.com/Audi-B5_A4-...g/Rack/ES2012/
    damn that sucks.. do you know the brand name of the one you used?
    i'm also kind of curious as to how many miles you put on it, or what caused the failure.
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    First rack replaced at 105k, now car has just over 200k and it happened when I was parallel parking(steering wheel cranked to full left position) when the fluid-began pouring out and /whining power steering motor made loud noises.....anyone know how much time in labor this job takes. Thanks again
    Deactivated Two Rings
    Jan 22 2008
    canada
    the racks suggested here are way more expensive than what others have used in the past. Do some searching on the forum. People have used rack doctor and jorgen auto, which are in the $200-300 range
    Aug 01 2004
    98 A4 1.8T
    Long Beach, NY
    Both sites were very helpful, thank you!! Where is the best price on outer tie rod ends? I figured I might as well do them too at the same time I do the rack replacement...
    Jun 25 2012
    I have a steering line leak. I can't find the part number for it. It's the line near the front drivers wheel with the curly shape and goes to the pump.
    Anyone know?
