Results 1 to 9 of 9
    Jun 28 2012
    Weird exhaust smell after cat back install
    Hello everyone,
    I just installed a Neuspeed cat back exhaust on my 2005.5 B7 S4 last night (sounds amazing, btw). After doing a highway run, I stopped at a red light and noticed a strange smell which was not present before the exhaust installation. I had all the windows open at the time.
    I parked, got out of the car, and checked to see if anything looked out of place, but it looks fine. I can't see/hear any exhaust leaks, but I will double-check that today. I smelled the exhaust coming out of the mufflers, and it does smell a bit strange. There are no error codes on the dash.
    Has anyone experienced this before? Does the exhaust just take awhile to break in or something? My friend mentioned that it kind of smelled like burning oil, but I don't see how a cat back installation would harm the engine like that. Maybe the lubricant we put on the exhaust sleeve to connect the cat back is slowly burning off or something?
    Any help is greatly appreciated!
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    Was it welded on? New exhausts can smell funky as can fresh welds.
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Jun 28 2012
    Nope, the new exhaust bolted right up. Although I assume the new exhaust had been welded together at some point.
    Established Member Two Rings richmeyer's Avatar
    Jan 24 2012
    its probably all the chemicals/lubricants that they use in the production process burning off. Should go away soon.
    CWDW
    DFWMM
    2004 S4 w/ some stuff done and stuff
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Its fine if its a new exhaust that hasn't been installed before. Sometimes the oil residue on it has to burn off or the packing material inside the muffler getting hot for the first time. I don't think its anything worrying over.
    Jun 28 2012
    Thanks for the replies everyone! I'll continue to look for any signs of oil leakage, and hopefully the smell will go away.
    Senior Member Three Rings Ricky P's Avatar
    Sep 29 2008
    2005 Audi S4
    Long Island/Brooklyn
    You forget to put the catalytic converter back on?
    Current: Silver 2005 B6 6MT - JHM 93 tune, catless Milltek, 19" OEM S5's
    Jun 28 2012
    I thought the point of a cat back was that your replacing everything after the converters
    Senior Member Two Rings KMAzz's Avatar
    Jun 03 2010
    2010 Nissan GTR, 05 S4, 03 A4
    Bethlehem,PA
    its normal. give it a few days to burn off everything and you'll be good to go.
