Results 1 to 14 of 14
    Feb 07 2006
    Boston MA
    Anyone know how much to torque the Hub bolt to the front spindle?
    I have search and found nothing... Here is the bolt I'm talking about.
    Any help would be great.
    Jul 19 2011
    Northern Minneapolis, MN
    until you hear it 'pinch' or chirp at you ;-)
    Oct 14 2009
    Okinawa Japan
    dude i cannot get that bolt OFF dammit
    impact, ect pita
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    Had to use a nitrogen bottle hooked up to an impact wrench to get mine off.
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Jul 19 2011
    MAP Gas and Kroil
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Nothing in the Bentley, points to the bolt and just says [Bolt] lol, i'm actually not as impressed with this one as the MK4 Golf/Jetta version, seems to be missing a lot of torque specs.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings CleverA4Name's Avatar
    Dec 09 2009
    2006 A4 2.0T Quattro 6MT, 2016 Audi SQ5
    Portland, OR
    Guys, I think he is wondering how to tighten it, not loosen it.
    F.T.W.L.T.B.D.W.I.C.T.W.
    -Trent
    Veteran Member Three Rings J.Owen's Avatar
    Aug 12 2010
    I run -361* of Camber.
    Bucks County, PA
    I have always heard 200 Nm + 180 degrees. which would equal 147 ft/lbs + 180*. Not sure how you would get that much torque anyway.
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    Jul 19 2011
    Quote Originally Posted by J.Owen View Post
    I have actually stripped out a few hubs by going to factory torque specs, and by a few, I mean like 70% of the ones i used to torque to spec...
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    Actually it 85 ft-lbs/115 Nm, then turn an additional 180° (M14 bolt). 140ft-lbs/190 Nm plus 180° for a M16 bolt.
    Aug 12 2010
    Bucks County, PA
    so there you go, 140 ft/lbs, not 147.
    Veteran Member Four Rings Lensch09's Avatar
    Feb 20 2004
    2022 B9 RS5 SB, 21 Rav4 Hybrid, some golf clubs
    Santa Clara, California
    I always thought this bolt was a one time use bolt.....
    -Dan
    2022 RS5 Sportback - Navarra Blue
    Previously:
    2016 Audi S4 Prestige with tons of boltons -Build Thread - http://www.audizine.com/forum/showth...016-S4-Ordered!
    2007 Audi A4 S-line Ti APR GT2871R
    1999 Audi A4 Avant (S4 replica)
    2000 Audi S4 Sedan (Stage III)
    1999.5 Audi A4 1.8TQM Sport (bolt-ons)
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Quote Originally Posted by Lensch09 View Post
    -Dan
    It's supposed to be
    New Build, 2010 Tiguan. Details to com
    Oct 14 2009
    Okinawa Japan
    Fuck that the bush is being reused, if it fails, the worst that will happen is 600threads may or may not back out. And the CV may or may not come out of its splined hole... I'm ok with my odds lmao
    -Shane Drake-
    >DRAKLOREs Build<
