Your best option is to build a bar in the trunk and fold the seats down during track use and run them like this (only cross the harness straps):
However, with this setup I HIGHLY suggest putting something like a loop or guide to keep the harness from moving side to side. It is key to have lateral support for the harnesses. A cheap and simple way too do this is to put a spacer between the harnesses on the bar and cross them as they go back to the bar. It is suggested that the webbing be crossed if the harnesses are mounted more than 18 inches appart.
Great read on installing harnesses:
http://www.schrothracing.com/sdocs/2...structions.pdf
Use it at the track and
roll them back up in the trunk for when you are street driving. There is no need for harnesses on the street. I ran a harness on my autox prepped civic for a long time, I rarely used it for street driving, so it was ok every now and then having the hassle of putting them on... and not being able to reach the door to shut the door with them was a pain lol. I ended up putting the stock belts in for street use and only ran the harnesses for racing. You do not need harnesses for street driving.
DO NOT RUN THEM TO BOTTOM OF THE BACKSEATS!!!! (Look on page 13 of the pinked PDF about installation) It is very dangerous to run that large of an angle with racing harnesses. they need to be a certain angle from horizontal to work. Below is linked what you should not do. This can cause serious back injuries if you ever are in an actual crash. Compressing the spine and possibly paralyzing you...
DO NOT DO THIS:
http://i171.photobucket.com/albums/u...Picture109.jpg
