can i retract rear brake caliper piston without the clamp tool on a b6 a4? Can i just loosen the brake bleed screw and relive the pressure and screw in the caliper with hand? and be fine?
03 A4 1.8T, silver/black, 5speed, Stage 1+ APR, gutted cat, APR Injectors, 6puck ACT unsprung clutch disc, light weight clutch masters flywheel, 034 street density tranny mount.
2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA| RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
-CP
2008 2.0t S-Line Ti 6MT Avant
2017 Q7 3.0t
Former USP CLUB MEMBER #136
02 A4 Quattro 1.8T
Votex kit, Neuspeed race springs and Koni struts, 18" AT Italia Flash Sport wheels, painted lowers.
Nuespeed: Chip, Exhaust, Short Shifter, Rear Sway-Bar, Dual Side-Mount Intercoolers, Forge Splitter.
02 A4 Quattro 1.8T
sic semper tyrannnis, canis
