Originally Posted by
quattroloco
like i said the dealer did the "FOB" with only one key... nothing in the ignition. he didnt even get in my car.
that is to program the fob... to actally get a new key, have it cut and start the car you HAVE to goto the dealer.
and like i said dont go Egay style... no one will cut the blank and without the dealer even if you get it cut it will start and then die because of the immobilizer.
like i said the dealer isnt too bad... under $100 and youll have a key and fob that works
Saw this old thread and thought I'd chime in. I accidentally broke the transponder immobilizer chip in my key fob (02 A4) when fitting a new shell.
The dealer wanted $150 for one key so I went online and spent $20 for two new blank keys + keyfob (with immobilizer chip inside) and $100 for a OBDStar VagPro key programmer
My original cut key was still good so used that to fit into the new fob/chip. Used Vagpro, key in ignition position 2 (don't start), select immobilizer function, read security code from ECU, selected program key, followed prompts and now have a new immobilizer chip programmed. For the cost the dealer wanted I can now program keys in the future and wont have to go to them. The locksmith charges me $25 to cut a double sided key. To program the KeyFob remote you just follow the procedure of one key in ignition and other key in door, etc...
Also you can buy a new immobilizer chip to fit inside a keyfob online for $2-3 (looks like a small capsule). I believe the P/N is ID44 or something like that. Once a immobilizer chip is programmed you can't erase and program again.
