Results 1 to 40 of 54
    Deactivated Three Rings
    Apr 22 2010
    Lots of spiders.
    Northeast US
    Anyone change fog light bulbs on a 2013 yet?
    Just wondering if it is any different from earlier models, what with the redesign of the front end.
    Have yellows to go in as soon as the car is delivered.
    Feb 13 2004
    Silicon Valley, CA
    should be the same as earlier
    Kevin - Moderator, Audizine
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    I would just open up the fender lining and try reaching them that way.
    Euro Tails Crew
    Feb 13 2004
    Silicon Valley, CA
    Here are the real simple instructions
    http://www.audienthusiasts.com/Proje...vinglight.html
    Apr 22 2010
    Lots of spiders.
    Northeast US
    Quote Originally Posted by Stubek View Post
    Thanks gents.
    Picking the car up on Saturday. Wife doesn't know it's in, and going to surprise her when we get back from her birthday trip.
    Let you all know if anything has changed with the MY '13 cars.
    Oct 27 2009
    Miami, FL | Boone, NC
    I believe the 13s have a different size fog light bulb...
    Sent from my Galaxy Nexus using Tapatalk 2
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings Audacious's Avatar
    May 03 2011
    yep, I think it's H8 instead of H11.
    Apr 22 2010
    Lots of spiders.
    Northeast US
    Well...my wife got the car Tuesday...were supposed to have had the car last Saturday...but a data link between the dealership and the state DMV went down last week...and they weren't able to deliver any cars until Monday the 2nd.
    Spent all day yesterday (July 4th) adding "goodies" to it, including the yellow Hoen fog light bulbs. Should have been a quick deal with the bulbs...but was far from it.
    Yes, the 2013 fog light bulbs are easily accessible from the wheel wells as in the past, but the Hoen yellow bulbs I purchased would not go in no matter what I tried. And I tried for the better (worse?) part of half an hour.
    After drving myself nuts trying all sorts of things, I finally put the OEM & the Hoen bulb side by side, and noticed that one of the three tabs on the Hoen bulbs was about 1/8 of an inch wider than the OEM bulb, and that ended up being the reason the Hoen bulbs would not turn into the fog light housing. Took some small metal snips, removed the necessary metal...and in they went. ARRGGHH!! This did not amuse me one bit, considering it was about 90 degrees yesterday.
    I have been using aftermarket bulbs in cars since the late 1960s, and this is the first time I have ever had an issue like this. Not sure if this is due to some change in the fog light assemblies in the 2013 A4s, as they are quite different from previous years, but folks with 2013 A/S4s may want to be on the lookout for this when changing bulbs.
    The install of the Valentine One wiring went smoothly, as always. Installing some Compact Air Horns on the RHS behind the fog light assembly was only mildly tortureous, and the few other small bits were also easy.
    The car was supposed to have been delivered with the Audi Rear Deck Spoiler & Side Sills painted & installed, as well as the chrome exhaust tips, but they all were delayed in shipping from Audi, so we hope to have everything in, painted, and installed by the middle of next week. Will post pics when the car is done.
    The car is basically a 4-door version of my A5, and it does drive just like it. We took an hour ride with it Tuesday evening, on some very narrow & twisty roads near where we live, and it was great. The 19" Hartman wheels & tires do make the difference. Just a shame that they no longer are available with the Sport Package. Bummer. But no matter, Achtuning were there to help...and all is right with the car.
    Senior Member Four Rings dbX79's Avatar
    May 24 2012
    2011 BMW 328i Coupe
    Atlanta,GA
    Yea I would assume there would be some slight changes even with bulbs but no one would know that until trying. Glad to hear you got the car you wanted. Those 2013 are a bit pricey for me but I just got my 2012 about a month ago so I'm happy with that.
    2013 S4 Ibis White | Black Nappa Leather | DSG | MMI Navigation Plus | B&O | Sports Differential |Carbon Atlas Inlays | 19" 5 Spoked Peelers | VAG Com |
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    What type fog bulb did you buy/use? Was it H11 or H8?
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    Veteran Member Three Rings vtheman's Avatar
    Jul 09 2011
    Crown Vic Interceptor
    California
    Quote Originally Posted by a5sport View Post
    And there is a good reason why it didn't fit. You were trying to stick an H11 (55w) bulb into an H8 (35w) socket. Not such a bright idea especially if the wiring is not up for it.
    May 24 2012
    2011 BMW 328i Coupe
    Atlanta,GA
    A4's use only H11's right?
    Aug 27 2008
    Houston Area
    Quote Originally Posted by dbX79 View Post
    I think the B8.5 refresh uses H8's for the fogs.
    2013 6MT S5 - Monsoon/Black
    Prem+ | Sport diff | Adaptive dampers | Nav | B&O
    Res AWE exhaust | USP intake | USS Sways | OEM 19" speedline | AluKreuz | 034 Trans mount | Interior LED | VCDS tweaks | F1 tint | Xpel PPF
    Previous : 2009 6MT A4 | Quartz/Black | Prem+ 2001 5MT A4 | Silver/Black | Premium pkg
    Oct 27 2009
    Quote Originally Posted by B8_Jim View Post
    Correct. Sendmeone installed aftermarket fogs on his B8.5 S4. He said they went in smoothly, and it only took him 5 min...
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    May 03 2011
    I said that like 8 posts up, but whatever
    Apr 22 2010
    Lots of spiders.
    Northeast US
    Quote Originally Posted by vtheman View Post
    "Not such a bright idea..." that wasn't intentional...was it?
    Yes...the 2013s are H8s...but was told by a Tech at the dealership they were H11s...because there were no specs available anywhere in April, when we ordered the car...hence the reason I ordered the H11s in the first place. There is no problem with the slightly added wattage on the wiring. Not that much of a difference. Going double or triple wattage over the OEM may cause issues, however.
    I've run 85/100 watt H4s in cars in the past, and never had any wiring issues either. Have had them in a pair 1990 SAAB 900 SPGs for the past 20 years.
    Active Member Two Rings matay's Avatar
    Oct 28 2012
    2015 Q5
    markham
    so for 2013 A4, H8 for foglights and wt type for the Lowbeam bi-xenon?
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by matay View Post
    most likely d3s like our b8's
    no way to know unless you take the bulb out
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Senior Member Two Rings Für Deutschland's Avatar
    Sep 24 2009
    DUN GOT WUN
    Long Island
    How about license plate bulbs, On my 2010 i swapped with led's which i'd like to do on my 2013 i'm picking up saturday. Anyone have any ides on bulb size?
    2016 Audi Q5 | Monsoon Grey
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by Für Deutschland View Post
    your '13 already has led plate light bulbs from the factory
    '21 SQ5
    Sep 24 2009
    DUN GOT WUN
    Long Island
    oh, lol, i feel dumb, I didn't know that. Well that's pretty awesome. Thank you
    Mar 26 2009
    SLC, UT
    i wouldn't! congrats on the car!
    '21 SQ5
    Senior Member Two Rings bigdadi's Avatar
    Oct 07 2010
    2012 A4 Quattro Tiptronic 2.0T
    Boston MA USA
    After seeing the easy fog light replacement, I bought a pair of H11 Hoen Yellow Endurance for my 2012 B8.
    12 A4 Quat 2.0T,
    02 A6 AvtQtr 3.0 (Sold),
    07 Subaru Outback LTD (Sold)
    Sep 24 2009
    DUN GOT WUN
    Long Island
    Quote Originally Posted by jlaudio View Post
    Thank you very much!
    Now i just have to decide what i want to do with fog lights, HID, yellow or xenon match, too many choices lol. I guess the best for yellow and match seem to be hoen still?
    Mar 26 2009
    SLC, UT
    seems to be the preferred choice. personally i like to run my yellow fogs with just the led DRL's running during rainy weather/snow. the offset of the yellow and blue led's looks spectacular and unique
    '21 SQ5
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    What about interior lighting On the b8.5? Is it all led or just the footwells like the b8?
    -cW
    2023 X3 M40i Alpine White
    Mar 26 2009
    SLC, UT
    -cW
    i have a b8.5 loaner and the interior lighting is the same as pre-facelift cars
    '21 SQ5
    Oct 07 2010
    Boston MA USA
    I purchased a pair of Hoen yellow fog and been sitting here for last 2-3 months. Next month when the weather gets warmer, I am sure to put them in. Yellow is the best color in bad weather, fog, rain & snow. Up in the mountain roads, you'll see all light poles are fit with yellow color bulbs.
    12 A4 Quat 2.0T,
    Established Member Two Rings c3A4's Avatar
    Aug 04 2012
    Toronto, ON, Canada
    I swapped all the bulbs to led in the interior except for the foot wells, only leds inside.
    Registered Member One Ring soundfx's Avatar
    Mar 25 2013
    Toronto, ON, Canada
    Cool
    Yes the 2013's now use an H8 35 Watt bulb in the fog lights. The H11 will also work but slight mod to the mount will need to be done.
    Hope this helps
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    just order some H8 HOEN endurance bulbs for my B8.5. Going to drop those in ASAP!
    Last edited by SleeperCar; 04-21-2013 at 06:12 AM. Reason: saw Davids instructions..... DUH
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Active Member One Ring Audi9512's Avatar
    Apr 18 2013
    (R.I.P 2009 G37s, 2009 Fx35)
    Puerto Rico
    How did that work for you? I orderd H8 led bulbs for my foglights tow but they came with a decoder cable i dont know if i really need that cable do i? Thanks..
    2013 Audi A4 Premium Plus Pkg!
    2009 Infiniti G37s "Bye"
    2009 Infiniti FX35 "Bye"
    Jan 03 2012
    Wilmington NC
    The install could not have been easier.... Go in through the wheel well. I followed davidb8s method on audienthusiast.com. It took me all of 15 minutes, and that's because I did it at night lol!
    One pointer, pull the wire out before twisting the fog bulb out
    2019 S4 Build
    IG: @steves_s4
    Apr 18 2013
    Puerto Rico
    Wow thanks :) cant wait tomorrow ill put mine in! What about the decoder cable? There is no need for it!?
    Jan 03 2012
    Wilmington NC
    Quote Originally Posted by Audi9512 View Post
    No, it should just be "plugnplay"
    2019 S4 Build
    IG: @steves_s4
    Senior Member Three Rings t3han0maly's Avatar
    Aug 31 2008
    2013 MB GLK350, 2016 Nissan Frontier PRO4X
    Atlanta, GA
    Hey man, I tried to send you a PM but didnt see the option to do that under your profile. Where did you wire your V1. I got mine a couple weeks ago and was planning on taping a fuse but not sure which one to use.
    2014 S4 P+ 6MT Glacier White Metallic/Black - MMI + Sport Diff + B&O + 19" Peelers
    The Ex's: 2013 A4 P+, 2009 Mustang GT (Whippled), 2008 Audi A3 (GIAC Stg I), 2003 Corolla (TRD S/C 16PSI Road Course Car)
    Apr 18 2013
    Puerto Rico
    thankss man, it was plug and play! ;)
    Quote Originally Posted by SleeperCar View Post
    Registered Member One Ring Mike.Ko's Avatar
    May 13 2013
    North Vancouver
    Thanks for the posts and info, will purchase a pair of 5K LED H8 bulbs for my S4.
    Mike Ko
    Audi Enthusiast/Owner.
    Employed at Capilano Audi, 3rd year.
    Top 10 in Sales for Audi in Canada for 2013.
    2014 Audi S4 S-auto daily
    2012 Audi A7 S-line gone
    2012 Audi A6 gone
    http://img542.imageshack.us/img542/3623/ckup.jpg
    Sep 27 2015
    OH
    13 a5 send pm price and where to buy, part numbers ?
    Jan 03 2012
    Wilmington NC
    2019 S4 Build
    IG: @steves_s4
