Anyhow, has anyone tackled this yet? I've compiled a list of the wiring I may possibly need using the B8 A5/S5 B&O diagram.
Connection From Amp - J525 | BitOne Input | Speaker | Connector | Pin | Color | Notes |
Center Speaker + | CH1 + | R158 | T32h | 5 | Blue/White | Changes to Blue/White at T17c, Pin 15 |
Center Speaker - | CH1 - | R158 | T32h | 17 | Black/White | Changes to Black/White at T17c, Pin 17 |
Front Left Tweeter + | Use Combined | R20 | T27a | 11 | Red/Blue | B101, Positive Front Left Speaker (Main Harness), not needed for BitOne |
Front Left Tweeter - | Use Combined | R20 | T27a | 24 | Brown/Blue | B102, Negative Front Left Speaker (Main Harness), not needed for BitOne |
Front Left Midrange + | Use Combined | R103 | T17d | 15 | Red/Green | B101, Positive Front Left Speaker (Main Harness), not needed for BitOne |
Front Left Midrange - | Use Combined | R103 | T17d | 17 | Brown/Green | B102, Negative Front Left Speaker (Main Harness), not needed for BitOne |
Front Left Tweeter/Midrange + | CH2 + | R20/R103 | T32h | 6 | Red/Blue | Shared with R20, R103, contains combined signal |
Front Left Tweeter/Midrange - | CH2 - | R20/R103 | T32h | 18 | Brown/Blue | Shared with R20, R103, contains combined signal |
Front Left Midbass + | CH3 + | R21 | T32h | 23 | Red/Blue | Changes to Red /Blue at T27a, Pin 20 (Main Harness) |
Front Left Midbass - | CH3 - | R21 | T32h | 28 | Brown/Blue | Changes to Brown/Blue at T27a, Pin 22 (Main Harness) |
Front Right Tweeter + | Use Combined | R22 | T27c | 11 | Blue/White | B103, Positive Front Right Speaker (Main Harness), not needed for BitOne |
Front Right Tweeter - | Use Combined | R22 | T27c | 24 | Black/White | B104, Negative Front Right Speaker (Main Harness), not neeeded for BitOne |
Front Right Midrange + | Use Combined | R104 | T17f | 15 | Red/White | B103, Positive Front Right Speaker (Main Harness), not needed for BitOne |
Front Right Midrange - | Use Combined | R104 | T17f | 17 | Brown/White | B104, Negative Front Right Speaker (Main Harness), not neeeded for BitOne |
Front Right Tweeter/Midrange + | CH4 + | R22/R104 | T32h | 5 | Red/Yellow | Shared with R22, R104, contains combined signal |
Front Right Tweeter/Midrange - | CH4 - | R22/R104 | T32h | 19 | Brown/Yellow | Shared with R22, R104, contains combined signal |
Front Right Midbass + | CH5 + | R23 | T32h | 10 | Red/Yellow | Changes to Red/Blue at T27c, Pin 20 (Main Harness) |
Front Right Midbass - | CH5 - | R23 | T32h | 22 | Brown/Yellow | Changes to Brown/Blue at T27c, Pin 22 (Main Harness) |
Rear Left Tweeter + | Use Combined | R14 | B487 | 23 | Red/Violet | Shared with R159, not needed for BitOne |
Rear Left Tweeter - | Use Combined | R14 | B486 | 22 | Brown/Violet | Shared with R159, not needed for BitOne |
Rear Left Midrange + | x | R105 | T32h | 8 | Red/Gray | |
Rear Left Midrange - | x | R105 | T32h | 20 | Brown/Gray | |
Rear Left Midbass + | CH6 + | R159 | T32h | 3 | Red/Violet | Shared with R14, contains full signal |
Rear Left Midbass - | CH6 - | R159 | T32h | 15 | Brown/Violet | Shared with R14, contains full signal |
Rear Right Tweeter + | Use Combined | R16 | B485 | 21 | White/Green | Shared with R160, not needed for BitOne |
Rear Right Tweeter - | Use Combined | R16 | B484 | 20 | Blue/Green | Shared with R160, not needed for BitOne |
Rear Right Midrange + | x | R106 | T32h | 9 | Red/Gray | |
Rear Right Midrange - | x | R106 | T32h | 21 | Brown/Gray | |
Rear Right Midbass + | CH7 + | R160 | T32h | 4 | White/Green | Shared with R16, contains full signal |
Rear Right Midbass - | CH7 - | R160 | T32h | 16 | Blue/Green | Shared with R16, contains full signal |
Subwoofer + | CH8 + | R157 | T32h | 25 | White/Yellow | |
Subwoofer - | CH8 - | R157 | T32h | 30 | Blue/Yellow |
Man does the table function suck! Next time I'm posting a PDF.....
If my theory and wiring chart is correct, you should be able to use this to wire up other processors (MS8) or LOC for your subwoofer, etc. You will want to use the "full" or "combined" signals wherever possible. After looking at the B&O schematic, it looks like there are things like microphone and telephone mute that go through the amp, so it doesn't look like it's a great idea to remove the amp completely in favor of a device like the Mobridge (though straight digital to digital sounds AWESOME!)
I realize I'm not 100% experienced in the Audi realm of car audio yet, so please forgive me if I've made an error above. I won't be able to confirm anything until I actually begin install. However, I hope to be building an awesome SQ install that gets plenty loud.
I will be using the factory locations for most speakers in the car and I will be removing the additional midranges and tweeters in the rear. I will be utilizing the rear midbass locations for some full range 6", removing the stock B&O sub to replace with some sort of sub stage, replacing the front midbasses with 7 or 8" speakers (based on depth), 1" tweets in the sails, 3" midrange on dash, and a 3" midrange in center. As I'm out of speaker outputs for the rear speakers, I might just run them from the factory amp, or run an Audio Authority 3xs to split up the front stage further and give me a couple more outputs for those rears.
Confused yet?
Stay tuned....The B8 would be the second OEM integrated install I've done, so we'll see where it takes me.
