Results 1 to 26 of 26
    Veteran Member Four Rings Akrion's Avatar
    Dec 24 2010
    What is the maximum power the B8 S4 DSG can handle?
    Hi guys,
    For some reason forums best friend did not provide enough answers and information regarding the 3.0T DSG limits.
    The more I look into upgrades the more I see the DSG as a concern since it’s is more or less a “Black Box” and it either works or not … but what are the limits of it in terms or power it can handle?
    I see 325ft-lbs as the number thrown around … but it does not seem that high to me. Any thoughts on this would be greatly appreciated.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by Akrion View Post
    Hi guys,
    I see 258ft-lbs as the number thrown around … but it does not seem that high to me. Any thoughts on this would be greatly appreciated.
    Considering the fact that a stock B8 has 325 lb-ft. of torque, I think your number is wrong.
    Dec 24 2010
    You are correct ... I was looking @ the 2.0T DSG Number ... sorry about that. I corrected it.
    Jul 11 2011
    2021 Ford F-150 Lariat PowerBoost
    I thought I read somewhere that its good for upwards of 500 lb-ft on the input shaft. It's buried in some thread here. Should be substantially higher than the output of our engine because I'm pretty sure they use an identical gearbox on the new S6 & S7 - which have the 4.0 twin turbo V8 putting out much more torque than the 3.0T.
    2022 /SQ7 P+ | Daytona Grey Metallic | Executive Pack | Carbon Inlays | Driver Assistance | EA825 4.0T (IYKYK)
    APR Stage 1 685+ HP (Planned)
    Gone But Not Forgotten
    C7.5 S6 - Moonlight Blue
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    2008 V10 TDI Touareg II - Floret Silver
    2006 V10 TDI Touareg - Reed Green
    Feb 08 2009
    2008 maxima,2012 S4
    I remember reading on wikipedia that, Audi 7 speed dsg have a torque limit of 450 ft lb. If you would like to know more about it just go on wikipedia and search for it.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    The usual culprit of drivetrain part failure is driveline shock, not torque.
    You can apply A LOT of torque as long as it is applied smoothly.
    Launching the car hard a lot will break the transmission much more quickly than added power.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    The DSG clutchpacks will start slipping beyond a certain torque point. The question is what amount of torque can the clutchpacks handle.
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by skiracerblah View Post
    This is true, but it's a dual clutch which means LOTS of friction surface area. Clutches with lots of surface area can typically handle lots of torque without slipping. I'm sure someone will eventually find out the limits. You're not going to find them "listed" anywhere though.
    Veteran Member Three Rings tins5's Avatar
    Sep 21 2011
    Delaware
    any tuned guys having issues with the clutch packs? It's probably too early
    Mar 26 2010
    US
    Quote Originally Posted by tins5 View Post
    Only the 6MT cars so far, due to high RPM launches.
    BMW M3 Competition X-drive
    Veteran Member Four Rings ilspazzaneve's Avatar
    Jul 18 2011
    Quote Originally Posted by omegax View Post
    "It has a torque handling limit of up to 600 N·m (440 lb·ft), and engine power outputs of up to 330 kW (450 PS; 440 bhp)."
    http://en.wikipedia.org/wiki/Direct-Shift_Gearbox
    Any 100-octane tuned B8 S4 will likely be slightly exceeding the power output limit advisory already, without ill effect.
    Veteran Member Four Rings well_armed's Avatar
    Sep 19 2012
    Now that the S6/S7 guys are flashing their cars well above the 500 mark, is it safe to say our DSG boxes can handle it?
    Dec 24 2010
    Quote Originally Posted by well_armed View Post
    I think is too soon to say that with confidence no? I would not think the DSG would fail the first time they floor the pedal ...
    Veteran Member Three Rings IceAero's Avatar
    Apr 27 2012
    Boston MA USA
    I drove the DSG on my chipped MKV GTI fairly hard for 100k miles and really it performed identically over those 6 years. I'm not sure which failure mode would be incited by too high of a torque load over time. Presumably the clutch just start to wear too fast? I think some people have had the clutch packs replaced. That wouldn't be cheap, but would it be that much more than a clutch and flywheel replacement on the 6MT? Thanks to our fancy dual-mass flywheel...
    2017 RS3 | 2022 Q5 TFSI e
    Sep 19 2012
    Remember that the S6/7 stock power numbers are pretty good, and they would have never dropped it in there if it diddnt work.
    Or did they beef it up for those cars?
    Feb 25 2013
    MI
    There's got to be a reason they go with the ZF 8 speed AT on the S8/RS7? Maybe the return on investment in building burlier DSG's just isn't in the cards for Borg Warner/Audi.
    Oct 30 2012
    Raeford NC
    I've done a little research on the subject of DSG power limits. While there aren't any exact numbers of what the particular model in the B8/8.5 S4 can handle there is a wealth of knowledge on how to make a DSG stronger. Bottom line, I will not put one single power mod on my car unitl someone figures out how to retune the mechatronic. Engagement should be firmer, redline should be comparable with the 6MT and available tunes, and for gods sake somebody make "M" mode function the way we all know it should.
    Sep 19 2012
    I am confident my car can handle the increased power. I've wailed on it for 5K miles without a single glitch.
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    I remember reading that it is rated at 450lb of torque.
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Mar 26 2010
    US
    Quote Originally Posted by ahcow View Post
    Looks like 550NM at 9k RPM (406 ft-lbs)
    http://www.audizine.com/forum/showth...?highlight=dsg
    Established Member Two Rings easytreez's Avatar
    Feb 28 2013
    Lake Tahoe
    Has anyone ever compared a dyno of a stock DSG vs 6MT? I would have to assume the 6MT has the upper hand as far as drivetrain loss.
    In the market for a B8 S4 | '08 Touareg V6 bone stock | '92 Gti VR6-T | 300+ whp at 12psi | T3/4 turbo | Wavetrac Diff | ACT sprung 6 puck | and a whole lot more...
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    +1 I've wailed on mine for 45k miles with no issues, just the occasional 1-2 hangup
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    no one can know that
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Oct 27 2010
    Michigan
    Quote Originally Posted by S4Pilot View Post
    I know seriously can't believe there hasnt been a software made to prevent auto upshift since the release of this car, wish it would behave like bmw M cars
    Sep 19 2012
    Any way we can look up the part numbers for the DSG box, S4 vs. S6?
    That would be the final verdict if they are using the same transmission...
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    They could be the same exact box as far as performance limits, but they might still have two different part numbers between the models to account for slight differences between the models not affecting those limits.
