Results 1 to 13 of 13
    May 13 2012
    Connecticut
    What is the difference between ET35 and ET45 on an 18 X 8 wheel?
    Newbie question, I know.
    Also, would the optimal tire size differ between ET35 and ET45 or would the same tire size (245/40/18) work fine with either?
    Thanks
    Senior Member Three Rings pDubs's Avatar
    Jan 12 2012
    2005 Kawasaki ZX6R, 1973 Honda CB350F
    Fairfax, VA
    10mm is the difference. The wheel will stick out 10mm further when bolted up to the hub on the et35. That will also give you 10mm more clearance on the inside.
    Here is a picture showing what offset is. Numbers are different but a wheels offset is the measurement in mm from the center of the wheel to where the wheel bolts up.
    Apr 11 2011
    clutter
    hawaii
    ^awesome response. And adding to that, though you have 10mm clearance inside the wheel well, it's 10mm LESS outer clearance (rim of the wheel to fender, as depicted in above)
    -roger
    Stock...
    May 13 2012
    Connecticut
    So it sounds like a ET45 would almost be better? I am not looking for any certain "look". Also, just to be sure, the tire size of 245/40/18 would be fine with ET45's, right?
    Veteran Member Three Rings NuVega's Avatar
    Feb 06 2010
    Las Vegas, NV
    I use to have wheels that were ET43 w/ 245/40R18 and it was fine, granted the tire was really, really close to the wheel control arm(approx 2-3mm away). ET45 may put you really close, possibly rubbing up against it, which I don't believe is a good thing. Unless you already have the tires then I don't know, but if you could get 235 tires that may be the better choice.
    May 13 2012
    Connecticut
    So is the consensus then that for 18 X 8 wheels with ET45, the best tire size would be 235/40?
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Quote Originally Posted by NuVega View Post
    Factory 18" wheels on a B8 S4 are 18x8 ET47. ET45 isn't going to rub on a B8 A4.
    May 13 2012
    Connecticut
    Quote Originally Posted by Stereodude View Post
    Thanks, Stereo. Should I run 235/40's instead of 245/40's? I wantto ensure I have ZERO issues with fittment.
    Feb 06 2010
    Las Vegas, NV
    Oh ok, sorry, I couldn't tell what model Audi the OP had.
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Quote Originally Posted by 34dean View Post
    If it was me, I'd run the 245s.
    May 13 2012
    Connecticut
    Won't there be more of a possibility of rubbing with 245's v.s. 235's? Is there an advantage to one over the other?
    Jun 22 2011
    A bunch of junk
    Detroit Metro Area
    Not unless you're running a really aggressive wheel fitment.
    245's are more bit more common and there are more tire choices in that size.
    BTW, you're over thinking this.
    Senior Member Three Rings PKaudi's Avatar
    Aug 21 2013
    Canada/ON/Oakville
    I am such a noob..
    Will et35 225/45/18s fit with b8 non-sports setup without any issues?
    Sent from my HTC One using Tapatalk
    2010 A4 Premium Ibis
    2007 Civic LX Teffeta White - Sold
