Tools needed:
Jack
Jack Stands
Breaker bar (You may need a cheater bar as well)
Depending on what style collar bolt you have you will either need a 14mm allen socket, or a 27mm socket. -- Look to see first before you go and spend money on the wrong tool.
You can find the 14mm allen socket in a kit that comes with a 10,14, and 17mm at Advanced Auto Parts.
If you need the socket you can pick one up at sears (Kinda pricey, but worth it... $25)
You also need a 12pt star bit (Found at napa) -
8mm
1. Remove the center cap from your wheel to expose the collar bolt/axle bolt. Inspect the ead of it to determine if you need the allen socket or a regular socket.
2. Hook up your socket and your breaker bar and break the collar bolt loose. I ended up standing on my breaker bar as the bolt was pretty much fused to the hub.
(Use an impact if available, but that should be common sense
Once it is broken loose, the bolt will be finger tight (believe me, I dar near bit the dust when I broke it loose)
3. Jack up the car (Both sides) and secure it with the jack stands.
4. Pull off the tire and remove the collar bolt.
5. Remove the 12pt bolts (x6) from the inner CV joint using your 12pt star bit.
The star bit is an 8mm
6. Once those are all loose you *should* be able to swing the axle up over the diff cap (up into the engine bay, towards the back of the car) and pull the axle out.
This is where it becomes the updated version, do NOT swing it up as it gets caught. Turning the wheel does not do anything for clearence. At this point, all bolts connecting the axle to the hub and the transmission should be out. Jack up the hub as far as it'll go so that the axle hangs at a 45*. At this point, the CV joint by the transmission will drop out of the diff cup and the axle will be laying on your subframe/connected at the hub. Hammer out the old axle from the hub and it'll come straight out through the bottom of the car next to the transmission tunnel. They will come out from the red circled area.
Depending on how the axle is assembled you may have to pull the wheel bearing housing loose to make enough room to do this, but with both of the axles I replaced (in the front end of the car) all I had to do was swing the axle up to the top back of the engine bay.
If it seems like your tolerances are really close, you might be able to make a little more room by turning the wheel all the way to the right or left, and try to "finess" it out of its home.
While you have the axle out, it may be a good time to change the wheel bearings (Provided you have a hub removal tool, and an on-the-car wheel bearing press).
7. Install in reverse order. I believe the collar bolt is supposed to be torqued to 95 ft-lbs and then turned another quarter turn (Some serious torque).
I've done two, can do the whole job in like a half an hour (if I don't change the wheel bearings). Pretty piece of cake. Don't forget to pack the grease in the inner CV joint... Oh, and don't get any of that grease in your hair *YUCK!*
