Results 1 to 21 of 21
    Registered Member Two Rings
    Jun 03 2004
    98 A4 1.8tqm
    Berkeley
    How to remove stickers from windows?
    I bought the car with two stickers on the front window that are annoying the sh*t out of me, especially because one of them is half off, but I cant just pull it off. And even if I could I know that there would be traces of the sticky stuff from the sticker. So any advice on how to get rid of them and any traces of them would be welcomed. Thanks.
    Registered Member Four Rings Zodiak's Avatar
    Washington DC
    razor blade + goo gone
    Oct 06 2004
    Minnesota
    Peel it off. then wash the window with some soap
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Registered Member Three Rings VtAudi's Avatar
    Feb 12 2004
    00' A4 2.8
    Burlington, Vt
    Ditto, WD-40 works good too
    Jun 03 2004
    98 A4 1.8tqm
    Berkeley
    Problem is that they're kinda caked on to the window. I have no idea how long they've been on there, but i cant peel it off. I guess Im going to have to try the razor blade method.
    As far as the WD-40 goes would I try to spray that on the edges of the sticker? or is that for taking the goo off after the sticker is off?
    Registered Member Three Rings BoostinA4's Avatar
    Jul 12 2004
    definatly use a razer blade, just make sure to hold it at an acute angle.....and also you can use gas, goo gone, rubbing alcohol, and or brake cleaner, just make sure it does not come in contact with your paint
    http://www.audizine.com/gallery/data...765sig-med.jpg
    http://www.cardomain.com/memberpage/589435/4
    -----FOR SALE HERE!!!-------
    ATP manifold
    T28 wastegate
    440cc greentops
    RS4 bumper
    (2) Sparco 3pt harnesses
    HKS ssq BOV w/adapter
    (2) 4 bar FPRs
    Senior Member Two Rings GOROSSI46's Avatar
    Jul 18 2004
    S
    Hair dryer
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    I got some nasty stickers off with a putty knife, and some warm soapy water.
    Registered Member Two Rings supraman786's Avatar
    Sep 12 2004
    1998 Audi A4 1.8T
    Addison, IL
    razor blade and windex, WD-40 work fine... jus spray the windex or wd-40 on the window where the sticker is and take the blade and scrape the sticker off...
    Sep 11 2004
    2000 s4
    los angeles
    Acetone should work well
    Registered Member Two Rings Convallo's Avatar
    May 01 2005
    01 A4 Avant, VW 337/GTI
    Midwest
    Oh boy. Go to the hardware store. Buy some razor blades. Carefully slide the blade under the sticker, and continue to push the blade underneath the sticker. All the while being careful not to DIG the blade into the windshield. Take some 409 cleaner and squirt the adhesive residue with it, and again take your blade and commense to remove any adhesive. Next week we will talk about changing tires.
    ACTIV+
    Veteran Member Four Rings bitterchild's Avatar
    Feb 16 2004
    audi is chit
    you mean checking tire pressure. acetone is seriously a good organic solvent. The adhesive remover from 3m is really good. Takes off the clear paint protector bra w/ no probs.
    concours show prep in the DC metro area
    turbos, rods, pistons, clutches, etc.
    Feb 15 2004
    99.5 a4
    monroe nj
    razor blade is the best thing to use...
    Previously: sivic
    GTA, Canada
    Heat and razor blade should take it off. Any remnants use goo-gone
    RippleChip (Ryan) - Moderator
    Audizine
    01.5 eh4 1.8T || 12 eh5 2.0T
    Veteran Member Four Rings Silvant's Avatar
    Feb 12 2004
    Past: 95 Stg3 UrS6 Avant, 01 Stg3 A4 Avant
    LA | CA
    will someone teach me how to drive a stick?
    Mr. Inappropriate Porno Avatar Man.
    " So do us all a HUGE FAVOR silvant...STOP breathing our air..and go kill yourself...you punk POS...."
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    I deal with this all the time at work for our DOT numbers and decals we put on the sides of the coaches. Get yourself several razar blades and some paint thinner..apply the paint thinner to a rag and wipe the area with the rag then use the razar blade to scrap the sticker off the window
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    Umm... do you guys pump your own gas?
    OK, that was not cool of me....
    The harder I practice, the luckier I get.
    - Gary Player
    Dodge RAM 1500
    Pittsburgh Area
    yes I do
    Dec 07 2004
    Originally posted by blacka4
    yes I do
    Sorry that was not meant for you, It was a sacarstic remark. I thought razorblades and goo gone was common knowledge for removing crap off your windows.
    - Gary Player
    Active Member Four Rings
    Thank god for you.
    Jun 03 2004
    98 A4 1.8tqm
    Berkeley
    Shit guys no need for the sarcastic remarks. I just wasnt sure what the best way to do it was
