Results 1 to 17 of 17
    Veteran Member Three Rings domantas's Avatar
    Jun 29 2011
    Chicago
    top speed on stage 3 car?
    I have read that top end on e01 is 190mph with stock tire size. Would stage 3 power with ECU limiters tuned out would be sufficient to reach close to 180+?
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    Realistically,? Done on a track of course, I wouldn't hesitate saying around 170-5ish... Bearing you have "Good" Brakes, plus Suspension modifications to aid in stabilization, as well as stopping from said speed.
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    I know some people will start chiming in but if memory serves me correctly stock S4 gearing will only allow, granted if you have enough horsepower to go to 186MPH +/- 1 for argues sake. I have personally reached 175 MPH GPS confirmed a few times but haven't found a long enough road to get me that extra 10mph. My car still had revs left and could have if I had enough road.
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Aug 05 2011
    Memphis, TN for now!
    Nov 02 2006
    Western Mass
    Quote Originally Posted by airjawed View Post
    Rev limiter hit at 185 +/- 1 was on the money
    ...For now
    clicky
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    180mph is fast. You're gonna need a good chunk of road to reach that but it's definitely possible. Look how easy this s4 hits 160ish
    Established Member Two Rings leopos69's Avatar
    Oct 08 2011
    1993 UrS4
    Madison AL
    180ish GPS then ran out of road but even with all my stabilization mods I wouldn't go any faster. The car was floating at 180.
    So much to do, so little money to do it!
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    gps confirmed 181. that was fast enough for me.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    Sure. I hit 145 in my k04 stock fueling s4. I could have gone faster but I took my blindfold off to slow down..
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
    Aug 05 2011
    Quote Originally Posted by leopos69 View Post
    I don't think the S4 was designed with any downforce consideration!! Feeling stable at higher speeds definitely requires aerodynamics for those speeds. I've done 150+ and depending on the car can feel very stable... in my Avant 130 doesn't feel good at all.
    Jun 29 2011
    Chicago
    would you think track density bushing set in the rear add advantage to stabilize the car in high speeds? I have powerflex set but when its wet or snow car feels very unstable. So far I have biltein sports sitting on eibach springs and front sway bar and whiteline endlinks.
    Aug 05 2011
    Quote Originally Posted by domantas View Post
    It is more about alignment set up for high speeds than bushings themselves. My car is set up with more toe-in which is great for lower speed turn in.... which in turn makes straight line high speed driving less stable. Ride height is also something to consider... having the nose of the car lower than the rear helps the car stick to the road at higher speeds. Having something like a cupra lip might be a simple aerodynamic change for high speeds as well.
    Having harder bushings is probably more about feel and maintaining geometry of the suspension under power and weight transfer... which is good. Not much of a consideration when just driving straight at high speed.
    Jun 29 2011
    Chicago
    so 0* toe or some toe out?
    Aug 05 2011
    I would see the range that is given for stock settings and put it towards zero.... so that would be a little toe in still. If you have changed your suspension height then it gets complicated but hopefully you have installed adjustable upper arms to bring the camber back towards spec.
    This goes for both front and rear. Rear alignment also effects turn-in vs straight line stability as well.
    The general rule though is toe out(front) and toe in (rear) for stability.... and then the opposite for steering... toe in (front) and toe out (rear) for quicker turns.
    Just do a little at a time. That is why I suggested to keep within or towards spec.
    Nov 30 2010
    saint louis , MO
    You guys are nuts. The b5 has the aerodynamics of a bowling shoe.
    Jun 29 2011
    Chicago
    well ok, we have the stability covered up. How about the power pumped by k04's, would they be sufficient to reach top speeds?
    Aug 05 2011
    I see some 170+ on K04's.
