Results 1 to 30 of 30
    Sep 24 2011
    Reading, Pennsylvania
    My Horn Beeps Everytime I Turn Left.
    WHY?? I already took out the fuse for now, but I want my horn to work. Any suggestions? I already searched.
    Jun 30 2008
    Erie, Pennsylvania
    Sounds like an intermittent short circuit in the clock spring that is happening when you tur it. The clock spring is the spiral wound cable that allows you to have electrical stuff in the steering wheel. It is not uncommon for them to break over time causing horn problems, airbag lights, etc. Mine had an issue where my Tiptronic "+" buttons never worked. I never felt like fixing it. But yours definitely needs fixed, because that's not cool.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Are the clock springs very specific when having to pick out a new/used one? Happen to know where the best place to buy one is?
    My horn hasnt worked for a few months, it has definitely calmed me down in the car when I get near bad drivers since there is NOTHING I can do about it.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 24 2011
    I just rev at people that piss me off. Cause I'm a douche like that. I just searched looks like they're about 40 bucks. Will a car without a working horn pass inspection?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by tsmitt View Post
    No.
    My 5-Speed Swap DIY
    - B6 USP
    Sep 24 2011
    Fml. Looks like I'm doing this this week then.
    Jun 30 2008
    Erie, Pennsylvania
    No. You definitely need a horn to pass inspection. At least where I come from. The button doesn't have to be on the steering wheel, but it has to be within easy reach of the driver. To slide a car through inspection cheaply we sometimes fit an accessory horn button (instead of the more expensive clock spring repair). This is on old trucks and such. We don't do such janky things to Audi's.
    The clock springs are somewhat specific. There are a few different versions:
    96>early 98 = 4D0 951 543 D (~$400)
    From mid 98 (after vin 8D-W-007 800) there are:
    1J0 959 653 C (~$150) *Note: this is the same as found in VW MK4's without ESP
    1J0 959 654 M (for cars with Tiptronic buttons and/or ESP, ~$500)
    I'm just looking at ETKA for this info, so I'm not sure on the actual differences and such. I'm assuming the later ones are completely interchangeable for the horn/airbag aspect. For example I would assume that if you didn't have tiptronic or ESP, you could use ANY 98.5+ clock spring and just leave the extra wires unplugged if needed. But if you do have tiptronic and/or ESP and you want to retain those features, you better get the correct one. Also, if you are getting this stuff from the junkyard, I would advise to steer clear of the 98 model year entirely if you can. So you don't end up on the wrong side of a vin split (ie: down in the VIN split dumps), which is never a fun place to be.
    Sep 24 2011
    ...$400...?
    Sep 24 2011
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    junkyard is your friend for parts like these.
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Three Rings Grip99's Avatar
    Feb 15 2011
    ny, ny
    Best is when NYC taxi's like to honk right when the light turns green. Couple of flames from the 2-step shuts them up.
    Mar 09 2008
    Torrington, CT
    Aftermarket is the way to go around me, usually $40-50 online as long as its not a tip version.
    Alot of the junkyards around here won't even pull the CS as they all say they're too difficult to do without breaking them.
    Very easy change though, just pull the wheel, unplug, unclip, reverse order and you're done.
    If you don't have vag, careful not to set off your airbag light. Especially if you need to pass inspection.
    Jun 30 2008
    Erie, Pennsylvania
    ...$400...?
    lol. yes. I'm pretty sure they have a guy in Germany whose entire job is to just make up prices. He just pulls them right out of...well, you know.
    And yeah, you *definitely* don't buy this kind of crap new. Plenty of good ones in the junkyard. The prices I posted were mostly for comic effect.
    Sep 24 2011
    Quote Originally Posted by Grip99 View Post
    Where can I get me some snazzy flames? Lol.
    And, I'll try to get around to a junkyard soon. They don't have many good ones around me though.
    Jun 04 2007
    Austin/DFW, TX
    Sorry for the slight derail, but I was wondering if I can just buy the 5spd one since I do not plan on using my TIP buttons?
    Would this wokr? http://www.ebay.com/itm/DORMAN-525-7...ff53e0&vxp=mtr
    My 5-Speed Swap DIY
    - B6 USP
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by biketsai View Post
    Yes, I'm assuming that would work fine - as long as your car does not have ESP. I've not actually done it myself, so I can't promise anything.
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    I'm sorry but that sounds hilarious! I think there used to be a video online of a guy that wired up his friends car horn so everytime he would hit the brakes it would beep. Funny stuff.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    Effective immediately:
    Left-hand turns are henceforth prohibited!
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
    Veteran Member Four Rings NickyAsixx3sixx's Avatar
    Oct 16 2011
    Levittown, NY
    Dont make lefts....like a UPS truck
    Sent from my DROID RAZR using Tapatalk 2
    2001 A6 2.7T - EPL TUNED, Bright Blue Metallic Vinyl Wrapped, ST coilovers, Miro 111s 19x9.5s all around on 225 tires, 3" SRM downpipes, AEM Meth kit, Magnaflow mufflers, JHM LWFW, JHM Stage3 clutch, B7 RS4 PP, SRM bipipes, JHM Solid linkage
    Established Member Two Rings B5RiceEater's Avatar
    Nov 09 2010
    brooklyn
    Tell them your horn works just turn left :-p youll pass inspection haha
    BOOST is Better than SEX! After Boost you dont wanna fall ASLEEP!!!
    Senior Member Three Rings shinamura's Avatar
    May 22 2011
    Detroit, Michigan
    personally i think thats kind of amusing haha, but not cool. lol
    Jun 30 2008
    Erie, Pennsylvania
    I always wanted to hook up the horn to my high beams. So whenever I honked, it also flashed them. Like a full sensory audio-visual attack. I really don't honk at people often. But when I do...I mean business.
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Your car is no longer an "Ambi-turner"
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Nov 03 2011
    All Over!
    Definitely a faulty clock-spring.
    It's worth noting though, it's a precision piece of equipment. Even new, there are specific instructions regarding fitment, and they are locked in transit in the straight-ahead position. The locking peg MUST be removed just before installation. If you get a used one, make sure you remove it from the car yourself, and use sticky tape to hold the rotating assembly in the straight-ahead position. If you rotate it in one direction, and you forget how many times you need to turn it to get it back central, your airbag light will be on. You'll also end up with fault code 00778 - Steering Angle Sensor (G85). The internal spiral / contacts are very delicate, and it doesn't take much to bust them.
    Personally, I wouldn't fit a used item. The airbag is just one of the things inside the car that I would not want to malfunction. Either not deploying when it should, or deploying when it shouldn't. Best of luck, and stay safe!
    1986 Type 85 Audi 90 quattro
    Sep 24 2011
    GREAT. Now I'm worried. Lol. On a side note, it also clicks when I turn left now that the fuse is off. Are we sure it's the clock spring? I was thinking my horn might be physically engaging itself when I turn. Ps. I have messed around in my steering column before, maybe I ruined it with my silly tom-foolery?
    Oct 29 2005
    10speed
    San Francisco, CA
    Just take the UPS truck route... but seriously I just imagined this in my head and LOLed at work.
    Anyone heard the Brian Reagan broken horn skit?
    - Clint
    Jun 30 2008
    Erie, Pennsylvania
    Personally, I would be more worried about driving around with a broken one (that is already known to be shorting out) than installing a used one. But that's just my opinion.
    Also, it is my understanding that only cars equipped with ESP have the G85 Steering Angle Sensor. It is certainly true that you must be careful removing and installing it. The amount of turns it has in each direction is not infinite. But on a non-angle-sensor version, I don't think a turn or so off center would create any problems. Ideally you do want to keep it on center, though. They are sensitive, but not precision (except in the case of the angle sensor, of course).
    The self-canceling turn signal is a function of the clock spring as well. So that might have something to do with the clicking. The airbag system has a very sensitive fault system that will detect resistance problems in the wires/clock spring if there are any. If the airbag light is happy, I wouldn't be worried about that myself.
    In reality, airbags themselves have a limited shelf life. After 10 years we should all be going back to the dealer any paying another $3000 for new bags/seat belt tensioners/etc so we can continue driving our cars safely. But nobody is doing that, are they. It's part of the risk of driving an old car. Some of the equipment may not work.
    Established Member Two Rings Buckle's Avatar
    Apr 23 2012
    Oakland, Ca
    I'm not really helping, but I must say that would be hilarious to witness
    Delta Sigma Phi '05
    Veteran Member Three Rings Roadtrippn's Avatar
    Sep 15 2011
    Hilton Head Island
    ^^^^ Yes maybe a video would help ;) Good luck man
    Registered Member One Ring Dunners75's Avatar
    Sep 01 2020
    Stockport
    Hi, sorry for the thread resurrection but I have the same problem!
    I pressed the horn one day (in anger) and noticed the note of the horn change. The rest of the journey saw the horn going off randomly every time I turned left. Took the fuse out to stop it but my car is coming up for its MOT so need to get it resolved.
    I sometimes get an Air Bag warning light do unsure if it’s all related to the control unit, but will replace the whole unit anyway to avoid messing with any of the internals.
    My question is, do I have to get the new unit coded to my car or will a replacement (used) unit just plug and play?
    If it does need recoding, how much roughly should I be looking to pay for this so I don’t get ripped off?
    Thanks for any help on this 👍
