Results 1 to 13 of 13
    Oct 23 2011
    Honolulu, HI
    Temporarily Use Water in Place of G12 Coolant?
    I drove to work today and once I parked the car, I noticed the G12 coolant leaking onto the ground. There is now a puddle of it and the G12 reservoir is empty. Would it be okay to fill the reservoir up with water just to get home where I can work on it? I live about a 30 min drive away.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Quote Originally Posted by daok808 View Post
    If you have zero risk of freezing, you will be ok. Well you are in Hawaii....
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    it will be fine.
    2000 Achat S4
    Feb 13 2004
    Silicon Valley, CA
    try to use deionized water if you can. If you can't and you are really only driving the 30 miles to get the G12, you will be fine. If you run straight tap water in there for a couple weeks of couple hundred miles, you want to flush your radiator and coolant system really good to get out any rust and minerals before putting the G12 back in.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    you can probably run pure water all year. As long as you don't see temps below freezing.
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Sep 17 2005
    Fremont, California
    Certainly. Use distilled water if you can, or at least something that has been filtered. Tap water can create deposits and such with the calcium, etc.
    Car can be run entirely on water if you really need it to, but it won't have the cooling capacity, will steam more, and can freeze.
    Oct 23 2011
    Honolulu, HI
    Thanks for the help, guys! I'm in Hawaii so it most likely won't freeze, haha.
    Jul 28 2009
    Philadelphia PA
    Max-
    I thought that pure water actually cooled better than a mix of water/antifreeze.....?
    I remember doing thermo problem in freshmen chem that proved that...ahhh those were the best days
    c8 a6 allroad
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    I have hear that the audi coolant has a special lube in it. I would say it is safe to go home but beyond that i would use the pink.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Sep 22 2009
    Vermont
    -_-...not to be that guy..but got ahead and use it. If you're driving an S4 and it breaks it won't be because you used water instead of coolant. Where the hell is everyone getting distilled water for their cars anyways?
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by mr.awesome View Post
    Grocery store has it.
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by rtl5009 View Post
    Max-
    Yep, pure water cools better than G12. However, G12 protects against corrosion, lubricates, and raises the boiling point of the mix.
    You also don't have to use distilled water (although I would recommend it). G12 is specially formulated to protect the cooling system against hard (mineral filled) water, such as tap water. Water with too many minerals for G12 to compensate for will leave deposits, which will ruin your cooling system.
    Veteran Member Four Rings S4UCE's Avatar
    Aug 21 2007
    Fairfield County, CT
    Quote Originally Posted by jeffrey146 View Post
    This is a great post
