Hey guys,
2005 S4 with 95k miles on the clock.
So I was sitting a red light today and I heard a sudden short, loud "whizz!" or something like that from the front end, and then as I drove home I noticed the steering getting heavier. I drove the 2 miles to get home and shut her off. The power steering reservoir is empty, and the fluid that was in there is now dripping onto my driveway from the back of the belly pan.
I'm thinking that I blew out one of the power steering hoses, and I could use some advice.
From what I've read from my search, it's a PITA to change these hoses. But is it easy enough to figure out which one blew?
On the PITA scale, how bad is replacing these hoses? I've had my S4 for about 6 months now, and have never had to do any work on it other than plugs, oil change and fuel filter. I'm debating about trying to DIY it, or take it to my independent Audi mechanic. He's excellent and reasonable, but I like to repair things myself when it's not too insane.
I'm a weekend mechanic at best, but in the past I've done quite a number of repairs on my old 99.5 B5, including the control arms & tie rod assemblies, crankcase breather system, valve cover gaskets and valley seals, wiper assembly, brake pads & rotors, tiptronic fluid & filter, etc.
If I decide to take it to the mechanic, what are the chances that I can drive the 12 miles without damaging the power steering pump? Even if I fill up the reservoir, I assume it would all drain out again within a few miles.
I do have a AAA premium membership, so flatbedding is available.
Thanks for any advice you can give.
